Loading...
Pages: 1 [2]   Go Down
Author Topic: Serial Errors - Uno + Servo  (Read 679 times)
0
Offline Offline
Jr. Member
No time to learn
View Profile
Osgeld, thanks!
zoomkat, neat, I'll give that a try!
Edit:
I tried using a diode (replaced the red wire in image). The voltage went from 5.01V to 4.95V. Would the capacitors have anything to do with that. Also, then I wouldn't be able to use the 5.7V with the Arudino, right?
The image is just a generalization of how the circuit is laid out.
Thanks,
-BBX
« Last Edit: November 17, 2012, 06:05:37 pm by BBX » Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
You probably have something wired wrong. Also, using a 9v transistor battery to power a servo won't work for long. Replace the 9v battery with four ~1.5v batterys supplying ~6v directly to the servo like below. Radio shack has battery holders if needed.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
0
Offline Offline
Jr. Member
No time to learn
View Profile
x_x Sorry about that. I have a full 19V PSU for the system, but I couldn't find something like that in Fritzing, so I made two 9Vs to show ~18Vin.
Edit:
Didn't even think about parallel/serial. Sorry again for the confusion.
-BBX
« Last Edit: November 17, 2012, 06:46:07 pm by BBX » Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
Quote
the diode will do that, all diodes have a voltage drop across the junction... 0.7volts is a good generic guess, but the exact number depends on the exact diode, temperature, etc. Though the datasheet is usually pretty good about nailing it down.
Logged
0
Offline Offline
Jr. Member
No time to learn
View Profile
I thought the idea was that adding a diode would increase the voltage at the 7805 around +0.7V?
Quote
You can add a small diode to the 7805 ground like below to up the 7805 output voltage to ~5.7v for better servo performance.
-BBX
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Quote
That's correct. Check how you have the diode is installed. You may want to remove the 7805 from your circuit and get it setup standalone first. "Breadboard" drawings are not useful to me as I don't use breadboards (have a nice one, but never used it).
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
