Loading...
Pages: [1]   Go Down
Author Topic: I need to change code from character to a string (I think)  (Read 258 times)
Burlington, Ontario, Canada
Offline Offline
Newbie
View Profile
I found a processing sketch and an arduino sketch that turned off and on an LED.  I am trying to expand the sketches so that I can turn off and on multiple LEDs.
In the following processing code I tried to change the port.write('L'); port.write('H'); to port.write('H1'); port.write('H2'); and so on but the Arduino sketch did not work.  I then changed the port.write('L'); port.write('H'); to port.write("L1"); port.write("H1"); but I could not figure out how to change the Arduino sketch.
So I guess I'm asking is how can I change the Processing and Arduino Sketches to get the Processing to send out L1 or H1 to turn LED1 on or off,
L2 or H2 to turn LED2 on or OFF.
Code:
//Turn LED on and off if buttons pressed where
  //H = on (high) and L = off (low)
  if(mousePressed) {
    if(rect1.pressed()) {            //OFF button
      currentcolor = rect1.basecolor;
      port.write('L');
    } else if(rect2.pressed()) {    //ON button
      currentcolor = rect2.basecolor;
      port.write('H');
  if(mousePressed) {
    if(rect3.pressed()) {            //OFF button
      currentcolor = rect3.basecolor;
      port.write('L');
    } else if(rect4.pressed()) {    //ON button
      currentcolor = rect4.basecolor;
      port.write('H');
  if(mousePressed) {
    if(rect5.pressed()) {            //OFF button
      currentcolor = rect5.basecolor;
      port.write('L');
    } else if(rect6.pressed()) {    //ON button
      currentcolor = rect6.basecolor;
      port.write('H');
  if(mousePressed) {
    if(rect7.pressed()) {            //OFF button
      currentcolor = rect7.basecolor;
      port.write('L');
    } else if(rect8.pressed()) {    //ON button
      currentcolor = rect8.basecolor;
      port.write('H');
This is the Arduino sketch
Code:
char val; // variable to receive data from the serial port
int ledpin1 = 10; // LED connected to pin 10 (on-board LED)
int ledpin2 = 6; // LED connected to pin 6 (on-board LED)
int ledpin3 = 7; // LED connected to pin 7 (on-board LED)
int ledpin4 = 8; // LED connected to pin 8 (on-board LED)
  pinMode(ledpin1, OUTPUT);  // pin 10 (on-board LED) as OUTPUT
  pinMode(ledpin2, OUTPUT);  // pin 6 (on-board LED) as OUTPUT
  pinMode(ledpin3, OUTPUT);  // pin 7 (on-board LED) as OUTPUT
  pinMode(ledpin4, OUTPUT);  // pin 8 (on-board LED) as OUTPUT
  Serial.begin(115200);       // start serial communication at 115200bps
  if( Serial.available() )       // if data is available to read
    val = Serial.read();         // read it and store it in 'val'
  if( val == 'H' )               // if 'H' was received
    digitalWrite(ledpin1, HIGH);  // turn ON the LED
  if( val == 'L' )               // if 'H' was received
    digitalWrite(ledpin1, LOW);  // turn OFF the LED
    digitalWrite(ledpin2, HIGH);  // turn ON the LED
    digitalWrite(ledpin2, LOW);  // turn OFF the LED
    digitalWrite(ledpin3, HIGH);  // turn ON the LED
    digitalWrite(ledpin3, LOW);  // turn OFF the LED
    digitalWrite(ledpin4, HIGH);  // turn ON the LED
    digitalWrite(ledpin4, LOW);  // turn OFF the LED
  delay(100);                    // wait 100ms for next reading
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
try to use different chars for different leds ... (simplest solution)
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Not in the code you posted.
Why can't you figure out that you now need to wait for there to be two characters to read, and when there are, read them both? The first defines the state and the second defines which LED the state applies to.
Logged
Pages: [1]   Go Up
Print
Jump to:
