Author Topic: I need to change code from character to a string (I think)  (Read 282 times)
Burlington, Ontario, Canada
I found a processing sketch and an arduino sketch that turned off and on an LED.  I am trying to expand the sketches so that I can turn off and on multiple LEDs.
In the following processing code I tried to change the port.write('L'); port.write('H'); to port.write('H1'); port.write('H2'); and so on but the Arduino sketch did not work.  I then changed the port.write('L'); port.write('H'); to port.write("L1"); port.write("H1"); but I could not figure out how to change the Arduino sketch.
So I guess I'm asking is how can I change the Processing and Arduino Sketches to get the Processing to send out L1 or H1 to turn LED1 on or off,
L2 or H2 to turn LED2 on or OFF.
//Turn LED on and off if buttons pressed where
  //H = on (high) and L = off (low)
  if(mousePressed) {
    if(rect1.pressed()) {            //OFF button
      currentcolor = rect1.basecolor;
      port.write('L');
    } else if(rect2.pressed()) {    //ON button
      currentcolor = rect2.basecolor;
      port.write('H');
  if(mousePressed) {
    if(rect3.pressed()) {            //OFF button
      currentcolor = rect3.basecolor;
      port.write('L');
    } else if(rect4.pressed()) {    //ON button
      currentcolor = rect4.basecolor;
      port.write('H');
  if(mousePressed) {
    if(rect5.pressed()) {            //OFF button
      currentcolor = rect5.basecolor;
      port.write('L');
    } else if(rect6.pressed()) {    //ON button
      currentcolor = rect6.basecolor;
      port.write('H');
  if(mousePressed) {
    if(rect7.pressed()) {            //OFF button
      currentcolor = rect7.basecolor;
      port.write('L');
    } else if(rect8.pressed()) {    //ON button
      currentcolor = rect8.basecolor;
      port.write('H');
This is the Arduino sketch
char val; // variable to receive data from the serial port
int ledpin1 = 10; // LED connected to pin 10 (on-board LED)
int ledpin2 = 6; // LED connected to pin 6 (on-board LED)
int ledpin3 = 7; // LED connected to pin 7 (on-board LED)
int ledpin4 = 8; // LED connected to pin 8 (on-board LED)
  pinMode(ledpin1, OUTPUT);  // pin 10 (on-board LED) as OUTPUT
  pinMode(ledpin2, OUTPUT);  // pin 6 (on-board LED) as OUTPUT
  pinMode(ledpin3, OUTPUT);  // pin 7 (on-board LED) as OUTPUT
  pinMode(ledpin4, OUTPUT);  // pin 8 (on-board LED) as OUTPUT
  Serial.begin(115200);       // start serial communication at 115200bps
  if( Serial.available() )       // if data is available to read
    val = Serial.read();         // read it and store it in 'val'
  if( val == 'H' )               // if 'H' was received
    digitalWrite(ledpin1, HIGH);  // turn ON the LED
  if( val == 'L' )               // if 'H' was received
    digitalWrite(ledpin1, LOW);  // turn OFF the LED
    digitalWrite(ledpin2, HIGH);  // turn ON the LED
    digitalWrite(ledpin2, LOW);  // turn OFF the LED
    digitalWrite(ledpin3, HIGH);  // turn ON the LED
    digitalWrite(ledpin3, LOW);  // turn OFF the LED
    digitalWrite(ledpin4, HIGH);  // turn ON the LED
    digitalWrite(ledpin4, LOW);  // turn OFF the LED
  delay(100);                    // wait 100ms for next reading
Netherlands
Online Online
try to use different chars for different leds ... (simplest solution)
Rob Tillaart
Seattle, WA USA
Seattle, WA USA
Not in the code you posted.
Why can't you figure out that you now need to wait for there to be two characters to read, and when there are, read them both? The first defines the state and the second defines which LED the state applies to.
