Topic: Codes working and then failing. (Read 2449 times) previous topic - next topic
johnwasser
> Has anyone actually tried to compile the codes?
I think I compiled one of the four versions you posted.
> How much memory do these things have?
- 32K Bytes of In-System Self-Programmable Flash program memory
- 1K Bytes EEPROM
- 2K Bytes Internal SRAM
> Will I be told if the program/sketch exceeds the memory limits of the board?
FLASH, yes.  SRAM or EEPROM, no.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
AWOL
#16
Nov 26, 2012, 10:10 pm Last Edit: Nov 26, 2012, 10:13 pm by AWOL Reason: 1
Example_menu seems to have a lot of strings not in PROGMEM.
Code: [Select]
//        This routine is now not used.
Nice. Thanks.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
liuzengqiang
Code: [Select]
Nice. Thanks.
I think some of the code might have come from my original alarm clock code for phi-2 shield and the OP is no longer in need of those.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
lost_and_confused
Guys,
That code is not used.  Granted.
It was blocked out so if there were problems I could quickly get back to it.
As it is remarked out, it won't be uploaded to the Arduino - right?
So really I could have 2 meg of comments and it wouldn't really change how much the ACTUAL sketch uses/needs.
Now I have to go through and remove all the old stuff from the original alarm clock code which I don't use/need.
Like the big font and remove all references to it.
I hope that gives me more memory.  Well, a LOT MORE memory.
What I am wanting to add may need a fairly good bit of memory.
When I get time I will try and and see what happens.
Thanks for now.
Riva
You don't have much flash remaining to store strings so unless you can trim your code and structures it might be worth considering some external flash for storing strings in.
Don't PM me for help as I will ignore it.
lost_and_confused
UPDATE:
Yes, thanks to all.
It is to do with size.  (but isn't it always?)
I got one of the later codes and cut out all the Serial.print() lines and stuff like that.
It works!
So it is now known that the code is filling up the available memory.
Drats - kinda.
The code I trimmed was the 10afya_W version.
Though there is/was a V11 that was a whole new ball game and I think it is now a lost cause as the additions are many.
So:  With my UNO - or equivilant - I am "out of memory".
Riva suggested using flash for storage.  But sorry, with my knowledge:  Storage of what?
(I don't know if you have seen "my" code.)
You say variables.  I can understand the idea but the implimentation etc...
I will leave it at that for now.   But thougth I would report what I have since learned.
AWOL
Quote
But surely the compiler would have told you that?
Don't you mean the VARIABLES are filling up memory?
lost_and_confused
AWOL,
Ok, sorry.  Terms.....
What ever.
I never saw an error from the IDE.  So the thought of "LOW MEMORY" never really entered my mind until the other night when I simply added two lines and it died.
I happened to notice the numbers at the bottom when it complied and noticed they were "close".
27,746 and 32,xxx...
Well, the learning curve is not quite as steep, but now I need to work out how to get it better "optimised" so I can add these other features - if at all possible.
