Author Topic: Powering bluetooth module from Arduino pro mini 5v  (Read 440 times)
I have a bluetooth module rated max at 3.3v, and an Arduino pro mini ATmega168, at 5v. When I power the bluetooth module through a resistor divider (1.2k +2.2k) I get around 1.68v only to the bluetooth module. Can somebody explain to my why this happens? Does anyone know how to power a 3.3v module from a 5v arduino?
Melbourne, Australia
Shannon Member
Lua rocks!
Resistor dividers are not very good voltage regulators (the drop varies by the current drawn). Look up a proper voltage regulator circuit.
I didn't know that. As you can tell, I'm completly new to electronics -.- Thank you!!
Now, More Than Ever
Try a couple of rectifier diodes (1N4001, 1N4002, etc.) in series.
+5----A_K----A_K-----| BT +V
Test circuit:
+5----A_K----A_K-----| 470Ω|----Gnd
         check for 3V  here
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
That Circuit Might work, If regulation wasn't important (It will vary about 300 mV from no load to about 200 mA and it isn't very thermally stable, Diodes are commonly used as temperature sensors in IC's like Processors. After all there's a whole lot of diodes in a Processor. It is also missing a 47uF cap. No Power supply should ever be without some bypassing. The voltage will range from about 750mV @ 0 C to about - 500 550 mV @ 80 C @ 100mA current. Not a lot really considering digital electronics but more than enough to vreate problems with any linear circuitry.
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Now, More Than Ever
Oh, man.
The diodes are sound enough.  The OP's just cobbling something together.
Does everything have to meet über-stringent design criteria?
If someone was working on something so critical that 2 mV per deg_C really mattered then he wouldn't be asking questions here anyway.
For that matter, I bet that the BT has on-board decoupling.
The diodes, something that everyone needs several of in his indispensable box of stuff, ought to enable the OP to get on with it - a practical means for the present.
Thank you for all the replies! I decided to use a LD1117V33 voltage regulator as described here: http://www.kobakant.at/DIY/?p=563
Hopefully it'll be helpful for somebody else in the future.
Boston, MA
use red LEDs (1.7v drop) in parallel.
http://www.toastedcircuits.com Lightuino LED driver: 16 sources, 70 sinks, remote controlled.  Also high powered LED drivers.
Anaheim CA.
Yes I agree but what if he had no clue to begin with... What then?
Bob
Now, More Than Ever
I guess he has cash to burn and time to wait.
