USA, OH
« on: November 16, 2012, 10:00:16 pm » |
What are next serial speed after 115200? I tried 230400 and 250000 - does not work; though, 131250 works fine but not 262500. Any ideas?
Wahiawa, Hawaii
« Reply #1 on: November 16, 2012, 11:10:54 pm » |
Dallas
Shannon Member
« Reply #2 on: November 17, 2012, 12:08:26 am » |
What are next serial speed after 115200? To what? The host computer (via USB)? Or something else?
USA, OH
« Reply #3 on: November 17, 2012, 12:20:04 am » |
yes, to host PC via USB. after some experimenting it seems like I can transmit with Serial.begin(250000); I tried increasing it to 251000 but failed to receive any data. MEGA can accept practically any number ( I tried up to 2048000), but real transmission speed is like 40% less then maximum speed of DUE
« Last Edit: November 17, 2012, 12:34:51 am by Stan09 »
Dallas
Shannon Member
« Reply #4 on: November 17, 2012, 12:37:18 am » |
Programming port or Native port?
USA, OH
« Reply #5 on: November 17, 2012, 01:11:26 am » |
Programming.
Dallas
Shannon Member
« Reply #6 on: November 17, 2012, 01:12:25 am » |
Try 500K, 1M, 2M.
USA, OH
« Reply #7 on: November 17, 2012, 01:14:35 am » |
As I said above, MEGA accepts 2M, but it does not affect communication speed. Speed stopes raising ~ after 250000. DUE with speed>250000 transmits garbage.
Dallas
Shannon Member
« Reply #8 on: November 17, 2012, 05:08:46 am » |
As I said above, MEGA accepts 2M, but it does not affect communication speed. Speed stopes raising ~ after 250000. There are two things at play... 1. With the new interrupt driven Serial, the sustained data rate will be lower (overhead of the interrupt service routine) than with the old blocking Serial. 2. The processor is only running at 16 MHz. If your program is doing anything more than pumping data out the serial port it is unlikely you will get a sustained data rate much past 250K. The highest sustained data rate I'm seeing is 463611 bits per second and the sketch does nothing but pump data. DUE with speed>250000 transmits garbage. Is an indication that there may be a problem with Serial on the Due. I suggest you post more details so others can try to reproduce what you are seeing.
USA, OH
« Reply #9 on: November 17, 2012, 05:22:54 am » |
very simple code: int x; void setup() {
randomSeed(analogRead(0)); } void loop() { x=random(300); Serial.println(x); } IDE 1.5 The board is connected through the programming port. Putty shows correct list of numbers coming from virtual COM. If you increase speed to, say, 252000 or even 251000, Putty shows garbadge. I played for couple hours trying to find any combination of Arduino/terminal program speed settings >250000 which does not produce garbage, and I failed. With Arduino MEGA same code generates correct transmission up to 2048000 May be even with bigger numbers, but I feel it does not make sense to go further, because it is not the actual transmission speed. It is just some correct handling of parameters, like, if speed>2500000 then speed=250000.
« Last Edit: November 17, 2012, 05:24:55 am by Stan09 »
Always making something...
« Reply #10 on: November 17, 2012, 06:53:03 am » |
I just did a quick test on the native port, measuring approx 849 kbytes/sec. Yes, that's kbytes/sec, not kbits/sec. On the native port, the baud rate setting is ignored. Data is always transferred as fast as both sides can go. I ran this code on Due, using Arduino 1.5.1. void setup() { SerialUSB.begin(115200); // baud rate ignored for usb virtual serial pinMode(2, OUTPUT); // measure pin 2 with frequency counter } void loop() { digitalWrite(2, HIGH); SerialUSB.println("Output is HIGH"); digitalWrite(2, LOW); SerialUSB.println("Output is Low"); }
I ran this Python script (from Claudio Indellicati) on my Ubuntu 12.04 64 bit Linux machine: # This script flushes every byte received on the serial port
import serial import sys
ser = serial.Serial( port = '/dev/ttyACM0', baudrate = 115200, parity = serial.PARITY_NONE, stopbits = serial.STOPBITS_ONE, bytesize = serial.EIGHTBITS )
if ser.isOpen() == False : ser.open() if ser.isOpen() == False : print "Can't open serial port" sys.exit(1)
while 1 : if ser.inWaiting() > 0 : ser.read(16384);
I connected a Fluke multimeter to pin 2 and measured approx 27.4 kHz (it fluctuates slightly). Each each cycle is 31 bytes, so the data rate is about 849 kbytes/sec. I repeated this test on Leonardo, Teensy 2.0 and Teensy 3.0 (changing "SerialUSB" to "Serial"), using Arduino 1.0.2 and the same Ubuntu 12.04 system running the python script. Here are the results: Leonardo: 1.842 kHz - 57 kbytes/secTeensy 2.0: 14.16 kHz - 439 kbytes/secTeensy 3.0: 35.09 kHz - 1088 kbytes/secIt's worth mentioning the speed changes dramatically depending on the software receiving the data. The Arduino Serial Monitor gives much lower speeds. Even the seyon terminal emulator gave speeds slower than the python script. At least with Linux, after a program closes the serial port and the kernel drivers' buffers are filled, data transmission stops. In that case, Serial.print() returns very quickly and a much higher frequency appears on pin 2. If anyone tries to repeat this test, please be sure to measure the frequency while the python script or some other program is actually receiving the data. It's probably also worth mentioning the USB spec says the maximum theoretical speed on 12 Mbit/sec USB is 1216 kbytes/sec, which accounts for protocol overhead, except the bit stuffing algorithm (which is data dependent).
Online
« Reply #11 on: November 17, 2012, 12:35:33 pm » |
Can you have a quick look at the output of dmesg? When I connect my Due it claims to be a high-speed device! If that's true then I guess we're not being limited by the maximum theoretical speed  I tried to do a loopback test - I didn't save the code but it would probably have just been something like: if(SerialUSB.available()){byte c=SerialUSB.read();SerialUSB.write(c);} I only got about 230Kbyte/sec into the Due - but most of the data was lost, only short sections near the beginning and end got copied back. Something to look into. Running your code, I only get 10.67KHz (~330Kbyte/sec) (I cross checked with stty -F /dev/ttyACM0 raw ; time cat /dev/ttyACM0 >out )
« Last Edit: November 17, 2012, 01:09:31 pm by stimmer »
« Reply #12 on: November 17, 2012, 01:13:51 pm » |
Sure, that's easy. Nov 17 09:48:35 preston kernel: [202782.848669] usb 2-1.3.1: USB disconnect, device number 32 Nov 17 09:48:38 preston kernel: [202785.850713] usb 2-1.3.1: new high-speed USB device number 33 using ehci_hcd Nov 17 09:48:38 preston kernel: [202785.943813] cdc_acm 2-1.3.1:1.0: This device cannot do calls on its own. It is not a modem. Nov 17 09:48:38 preston kernel: [202785.943890] cdc_acm 2-1.3.1:1.0: ttyACM0: USB ACM device Nov 17 09:48:38 preston kernel: [202785.945261] input: Arduino LLC Arduino Due as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3.1/2-1.3.1:1.2/input/input37 Nov 17 09:48:38 preston kernel: [202785.945616] generic-usb 0003:2341:003E.001E: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Due ] on usb-0000:00:1d.0-1.3.1/input2
Yes, your point is valid, the theoretical speed is not limited to 1216 kbytes/sec. In fact, I just looked at the USB 2.0 spec. Table 5-10 on page 55 (83rd page of the PDF) says the theoretical maximum (with packet overhead, but not bit stuffing overhead) is 53.248 Mbyte/sec. But in practice, the actual speed is 849 kbytes/sec, at least with this particular test. I'm pretty sure the test is not limiting Due's speed, since Teensy 3.0 is able to run 28% faster on the same test. Teensy 3.0 is only a 12 Mbit/sec device, so it does face the 1216 upper limit. I believe Due could run much faster, with a *LOT* of programming work. The SAM3X datasheet says the chip supports both software polled FIFO and DMA. I've looked briefly at Due's USB code, which seems to be Atmel's reference code. It appears to be using the FIFO approach. The Teensy 3.0 code is using DMA, because Freescale's chip does not support a polled FIFO interface. Maybe someone from Atmel will take notice of the actual speed their top-end chip achieves relative to another silicon vendor's low-end chip... and dedicate some time to improving their reference software to use DMA? Then again, 849 kbytes/sec is pretty speedy, in the context of most projects where Arduino is used.
« Last Edit: November 17, 2012, 01:20:01 pm by Paul Stoffregen »
« Reply #13 on: November 17, 2012, 01:32:00 pm » |
Wow, that's quite a difference. I am running on a very fast desktop machine (an i7-3930k) and I'm using the Due beta hardware, since the release Dues I purchased on still on backorder. Still, I wouldn't expect such a huge difference. Edit: I noticed you're redirecting the data to "out". Sending to /dev/null might be a better test? On most modern PCs, I wouldn't expect this to make much difference. But in the early days of testing Teensy 2.0, I saw a laptop where attempting disk I/O in the same test as USB caused a significant slowdown. The same test on a desktop machine (both a few years ago) showed nearly the same speed with and without disk I/O. If you post a complete benchmark program and specific steps, I'll run it here and share the results.
« Last Edit: November 17, 2012, 01:37:11 pm by Paul Stoffregen »
« Reply #14 on: November 17, 2012, 03:54:41 pm » |
I don't see how measuring LED pin frequency relates to original question: how many characters per second can be transferred from Arduino to PC.
31 bytes are transmitted (or placed into a hardware buffer that gets transmitted) per cycle. Measure the frequency and multiply by 31 to get the average bytes per second. or, if you like rather: what maximum port settings on Arduino and receiving terminal allows receiver recognize characters correctly.
That's not how the native USB port works. Bytes are written into USB packet buffers (on Due, using a hardware register that accesses the buffer in a fifo manner). When the software and drivers on the PC are ready to accept data, the USB host controller on the PC schedules USB bandwidth and sends tokens when the device is allowed to transfer data. If data is waiting in a packet buffer, Due's hardware automatically transfers the data at the full USB speed. The net transfer rate depends on how often the PC software and drivers request data, when the computer's USB host controller chip schedules USB bandwidth (other USB devices are the main factor) and how frequently there is a packet buffer ready to transmit when the host controller sends the token allowing the transfer. That is absolutely unlike hardware serial used on the programming port, where a fixed baud rate is used and it's up to the receiver to respond to the incoming data quickly enough (or implement additional handshaking lines to cause the transmitter to pause). It makes no sense, in the context of the native port, to say "allows receiver recognize characters correctly". The speed is fixed at the native USB bit rate, 480 Mbit/sec for Due, but data is only transmitted when all 3 components (receiving software, host controller chip, and Due's packet buffers) are ready to transfer data. I'd suggest to use Putty as reference receiving terminal program.
Displaying the data in a scrolling window is a poor benchmark for native port. The rate putty requests data will depend on many complex factors of the windowing system and graphic card driver. the native one accepts any speed settings (as was noticed above, it just ignores it) but real data transfer is very slow, like, few characters per second.
Your measurement of a few characters per second differs tremendously from my measurement of 894 kbytes/sec. I specified exactly how I tested, with complete code for both the Due and PC side. If you would do the same, perhaps someone can try reproducing your test results?
« Last Edit: November 17, 2012, 03:59:03 pm by Paul Stoffregen »
