My question is this: is it possible to buy a glass bead thermistor and enclose it in copper tubing and still get an accurate reading? The thermistor I have in mind is Digi-Key Part Number 495-2135-ND and I'm thinking of encasing it in either a plumbing stub out, or some kind of copper pipe with one end braised or pinched shut and then filled with a high temperature silicone sealant.
That is the way most temperature sensors are used in industrial applications, (typicaly J or K thermocouples or RTD based sensors), using a so called 'thermowell', that isolates the sensor from the medium to be measured while still accurately reflecting the temperature of the medium. No need to fill the the well with any liquid (in fact that is a safety issue in itself), just having the sensor tip mechanically in contact with the far inside end of the thermowell works just fine. The use of a thermowell also allows the sensor to be removed for testing or repair without needing to shutdown the industrial process to remove the sensor safely.
The environment that the probe will be in is likely to never be much above 200* C, but it will be quite humid. Is this possible?
Given time the inside end temperature of the thermowell is the same temperature as the medium, that is the whole point of using one.
Be sure any sensor type you use is rated to well above the maximum temperature the medium can reach, and that includes any lead wire of the sensor inside the thermowell, which is usually the limiting factor.
Lefty
