Loading...
Pages: [1]   Go Down
Author Topic: Controller Hang whenever execute both functions(Parsing File and Writing File)  (Read 451 times)
Offline Offline
Full Member
View Profile
I am trying to create database by using JSON and SD library.
But i stuck in a problem "Controller hanging" after removing lot of stuff to make Memory Efficent Solution still i happens again.
Specifications
Flash 128k
SRAM 16k
Hardware
Offical Arduino Ethernet Shield
Zigduino board
To debug problem four tests were perform
Test 1 Only Parsing funtion Call
Status Ok
Test 2 Only Writng funtion Call
Status Ok
Test 3 Only Parsing funtion Call
Status Ok
Test 4 Both funtion Call
Status Hang
This the code and outputs of all tests attached .Status ok in zip file due limitation of 4 files
Code:
#include <aJSON.h>
#include <SD.h>
File myFile;
char* readFile(char* file)
  Serial.println(FreeRam(),DEC);
  char buf[30];
  char strFile[600];
  int16_t  readed;
  myFile = SD.open(file,FILE_READ);
  if(myFile)
    readed = myFile.read(buf,30);
    buf[readed] = '\0';
    String stringOne =  String(buf);
    while( readed > 0) {
      buf[readed] = '\0';
      stringOne += String(buf);
    myFile.close();
    stringOne.toCharArray(strFile,stringOne.length()+1);
    //Serial.println(strFile);
    return strFile;
    Serial.println("Fail to open file");
void parseFile(char* object)
  char* pch =readFile("test.txt");
  Serial.println(pch);
  aJsonObject* root = aJson.parse(pch);
  if (root != NULL) {
    Serial.println(F("Parsed successfully 1 "));
    aJsonObject* query = aJson.getObjectItem(root, object);
    char *json_String=aJson.print(query);
    Serial.println(json_String);
    Serial.println(F("**"));
    free(json_String);
    free(pch);
    Serial.println(F("Parsed unsuccessfully 1"));
  aJson.deleteItem(root);
void writeDb(char* object)
  char* buff = readFile("test.txt");
  //Serial.println(buff);
  Serial.println(F("HANG POINT"));
  aJsonObject* root = aJson.parse(buff);
  if (root != NULL) {
    Serial.println(F("writdb successfully 1 "));
    aJsonObject *tmp = aJson.createObject();
    aJson.addStringToObject(tmp, "value1","1101");
    aJson.addStringToObject(tmp, "value2","1102");
    aJson.addStringToObject(tmp, "value3","1103");
    aJson.replaceItemInObject(root, object, tmp);
    SD.remove("test.txt");
    delay(100);
    myFile = SD.open("test.txt", FILE_WRITE);
    // if the file opened okay, write to it:
    if (myFile) {
      char* json_String = aJson.print(root);
      myFile.print(json_String);
      myFile.close();
      Serial.println(F("FileClosed"));
      Serial.println(F("WR**"));
      //aJson.deleteItem(tmp);
      free(json_String);
      free(buff);
      Serial.println(F("File Not Truncate"));
    Serial.println(F("wrtidb unsuccessfully 1 "));
  pinMode(SS, OUTPUT);                       // set the SS pin as an output (necessary!)
  digitalWrite(SS, HIGH);                    // but turn off the W5100 chip!
  if (!SD.begin(4)) {
    Serial.println(F("initialization failed!"));
    return;
  parseFile("config0");
  Serial.println(F("Parse done"));
  writeDb("config0");
  Serial.println(F("Write done"));
  // Nothing to do
I really need suggestion because after playing 10 hours with this now i am in Blackout Stage. smiley-cool
« Last Edit: November 18, 2012, 11:17:06 pm by Cybernetician » Logged
From Idea To Invention
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
Code:
Please note that, at present, the String library has bugs as discussed here and here.
In particular, the dynamic memory allocation used by the String class may fail and cause random crashes.
I recommend reworking your code to manage without String. Use C-style strings instead (strcpy, strcat, strcmp, etc.).
Logged
Offline Offline
Full Member
View Profile
Thnx Nick Gammon
Quote
Ok.  One more question
Is this is a way about which you are suggesting?
Code:
  myFile = SD.open("config2.txt", FILE_READ);
  Serial.println(myFile.size());
  char* buf = (char*) malloc(myFile.size());
  readed = myFile.read(buf,myFile.size());
  Serial.println(readed);
  myFile.close();
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
How big is this file?
Logged
Offline Offline
Full Member
View Profile
Quote
At this time less than 300 bytes.
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Don't do this
Code:
    if (myFile) {
it is at least a bug waiting to happen. You should always use an explicit test such as if (myFile!=NULL)
Mark
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
  char strFile[600];
  if(myFile)
    return strFile;
One path returns something. One does not. On any reasonable system, you'd be warned about that.
As Nick points out, using the String class is a bad idea. It isn't even close to being necessary in your case, since the read function is using a char array and the output is a larger char array. Copying the data from one to another using a for loop instead of dynamic memory allocation is going to waste far fewer resources.
Snipped down like this routine is, though, makes your real problem far easier to spot. You have a local variable, strFile, that goes out of scope when the function ends. Yet, you return a pointer to that memory. When the function ends, you've got a pointer to memory that no longer belongs to a function, and is, therefore free to be reused in any amount anywhere. Not a useful thing to have.
Define the array in the caller, and pass a pointer to the array to this function to fill.
Logged
Offline Offline
Full Member
View Profile
After taking break and enjoying weekend now i am out from Blackout Stage.
Quote
Ok next time i take care of that.
Quote
Yes, you are right. (Nick, sorry for PM. I really don't know why there is PM option if this is not useful)
Quote
Yes, that's why i tried both ways.
Quote
Yes, After taking break and enjoy the weekend to recover mysellf from Blackout Stage i start debugging again and isuue on these lines find as earlier you mention that.
Code:
free(buff);
Code:
free(pch);
Issue solved and i modify it according to your and holmes4 suggestion.
But this problem open lots of issue front of me i start playing with this platform a month ago (but i am not a bad engineer smiley-wink). Is there really issue of system crash due String, free(), and malloc. In a post http://arduino.cc/forum/index.php/topic,115552 mention by executing this sketch system wil crash.
Code:
#include <MemoryFree.h>
  int n = 0;
  while(n <=100) {
    int u = 20*n;
    int v = 30*n;
    String str = String(n) + ", " + String(u) + ", " + String(v) + [color=red]", " + String(freeMemory());[/color]
    Serial.println(str);
    n++;
  Serial.println("Done");
result comes in favour of post but if it is modify like that system execute smoothly
Code:
#include <SD.h>
  int n = 0;
  while(n <=100) {
    int u = 20*n;
    int v = 30*n;
    //int x =
    String str = String(n) + ", " + String(u) + ", " + String(v);
    str        = str + String(n) + ", " + String(u) + ", ";        //coment this line and next indicates test 1
    str        = str + String(n) + ", " + String(u);                //coment only this line indicates test 2.
    str        = str + ", " + String(FreeRam(),DEC);            // execute all lines indicate test3
    //Serial.println(FreeRam(),DEC);
    delay(100);
    n++;
tests output attached in txt format. Actually i want to say that there is some patterns on which system will crash why?
Is this is due to bug OR our mistake logically.
NOTE :Spelling and grammer mistake ignore thnx it's your suggestion which makes my playground play-able smiley-cool
« Last Edit: November 19, 2012, 09:33:02 am by Cybernetician » Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
Do not use the String class. Is there something about that simple statement that escapes you?
Logged
Offline Offline
Full Member
View Profile
Quote
Yes ,there is some patterns on which system will crash why? Is this is due to bug OR our mistake logically.
Actually i execute the test mention here http://code.google.com/p/arduino/issues/detail?id=857 it's results also fine.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Get rid of EVERY SINGLE instance of the String class in your code. Then, if it still has a problem, we'll talk.
Logged
Offline Offline
Full Member
View Profile
ok thnx for your suggestion.
Logged
Pages: [1]   Go Up
Print
Jump to:
