I must say this project has been a hugely important learning experience for me, it really helped me grasp some deeper concepts I hadn't really wrapped myself around yet, I am also starting to realize just how much is possible if you think outside of the arduino core
This project is far from done, I still have code to put in to make it work as an I2C slave as well, this way it will support either PWM input OR I2C, main reason is because I am also building a custom 433MHz bidirectional radio system for this airplane and once that is complete it will have an I2C bus, this way I can give very precise commands and also read some data back from the controller, but until that is complete I want to still be able to fall back on standard RC receiver PWM. I also want to remove all use of delays in the code and use timers, it really isn't all that required per-say on this project, but I want my code to be as efficient as possible.
I will be sure to come back and post a video of the airplane working with all of the high powered lights once I have it installed on the plane
