Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Arduino clones with more RAM than Uno?  (Read 2110 times)
Tacoma, WA
Offline Offline
Full Member
Arduino rocks
View Profile
Check out this improved 1.0.2 IDE: http://arduino.cc/forum/index.php/topic,118440.0/topicseen.html
You'd think they'd roll those improvements into the new 1.5 IDE, but I guess not. Can lead a horse to water, can't make him drink....
Logged
Brian from Tacoma, WA
Arduino evangelist - since Dec, 2010.
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
That's probably the IDE that was referred to in the post I saw, not the 1.5 IDE!
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Tacoma, WA
Offline Offline
Full Member
Arduino rocks
View Profile
Well if the improvements don't make it into the final 1.5, I'm sure those guys will apply them to 1.5 afterwards, like they did with 1.0.2..
Logged
New York
Offline Offline
Full Member
xronosclock.com
View Profile
WWW
I used FreeRam function to test how much RAM is being used.
Running my clock sketch it shows from 1167 to 922 available (depending which menu I'm in).
However as soon as I enable Waveutil.h library it jumps down to 110 bytes. I'm not even playing audio at this point. So I don't think there's anything I can do to optimize it (I don't want to mess with WaveHC library) other than upgrade RAM smiley-sad
Logged
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, and purchasing info smiley
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
How about posting your clock sketch?
Logged
New York
Offline Offline
Full Member
xronosclock.com
View Profile
WWW
Ok smiley
Logged
Dallas, TX USA
Offline Offline
Edison Member
View Profile
Look at the nm output.
You can see what is eating up your space.
The wavehc stuff appears to be commented out however
a a quick looks show two 512 byte buffers in wevehc.
Another big guy is a 256 byte shadow buffer for the graphics.
That is quite a bit just right there.
Total BSS without wavehc is currently 0x2c8 which is 35% of your
total RAM. Add in 0x400 for the wavehc buffer1 and buffer2 buffers and you up to 0x6c8
which only leaves 0x138 for everything else including stack  and
I'm sure there are other variables in the library as well too.
There are several variables in the main sketch that look like they are not
changing and could (should) be declared const to eliminate some storage there.
The wavehc does run on m168 and will automatically drop the buffers down to 256 if on
that part. There are some other limitations that come with that (bit rate etc) but you
may want look in the wavehc header and see if you can get away with using the smaller
buffers by patching the defines like they are on a m168.
Best thing is to run nm and objdump to start looking at where the memory is going
and see if there is anything easy (like putting the wavehc in m168 mode) that can be done
to save RAM.
--- bill
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Duemilanove-style 1284 is not hard to make.
http://www.crossroadsfencing.com/BobuinoRev17/1284_thruhole2.JPG
I sell bare boards for $5 shipped to US locations, scrounge  the parts  you need or pick up for ~$15 at mouser.
On board (MIKROE483) or off board USB/Serial (FTDI Cable or similar) supported too.
PL here www.crossroadsfencing.com/BobuinoRev17/
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
New York
Offline Offline
Full Member
xronosclock.com
View Profile
WWW
to save RAM.
--- bill
Wow thank you! I'll give it a try. I also had no idea that declaring consts instead of variables will save ram.
That's a beauty!  I think I'll order a PCB from you. Will it work with 644p? I had hard time finding 1284, they seem to be out of stock almost everywhere. I did request 644p sample from Amtel and it's on it's way.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Yes, 1284p and 644p in DIP at least have same pin out.
Lefty
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
@Bratan
  CrossRoads could probably hook you up with a chip. I have purchased several of CrossRoads PCBs and one of his Bobuinos that is loaded with features! CrossRoads does some great work!
  Also, on the subject of the 1284, I am using one of CrossRoads SMT 1284 boards to make a 20MHz version for fun. Someone recently made a bootloader so, that the chip will work properly at the higher frequency. I am considering putting a socket for the crystal to sit in so that I can try other frequencies. The socket will be easy to remove later if I do not like it.
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Thanks cyclegadget smiley
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
I took a look at your sketch. Which DS1307 library are you using?
As well as changing the variables that represent unchanging data (e.g. pin numbers) to const, another easy win is to replace Serial.println("text") in setup() by Serial.println(F("text")).
I was unable to find monthShortStr(), but I suspect the month strings are another candidate for moving into PROGMEM.
Table divider[12] occupies RAM but appears to be unused.
Variable tempString should be local to the function in which it is used, like timeString. Similarly for tempChar.
Logged
vermont
Offline Offline
Full Member
View Profile
i had a similar requirement for large ram and was given one of your m1284 boards. im very impressed with the design. do you have a link to a bootloader? also can you tell me what avrdude command line would be used to load a small test program to that with a com5 dongle?
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
 Here is the thread about the 20MHz bootloader for the 1284P. I have not tested it yet.  http://arduino.cc/forum/index.php/topic,128604.msg968632.html#msg968632
Here is the bootloader I use for boards from CrossRoads https://github.com/maniacbug/mighty-1284p
By the way, the board has to be selected as Bobuino or your pins will not match. There are other 1284 variants that have different pin mapping. The problem may apply to the first link I gave you.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
