Topic: What is wrong with this code? (Read 798 times) previous topic - next topic
Raptor5
int cmdNumber(char* cmd)
   char* cmd1;
   strcpy(cmd1, cmd);
   //Serial.println("123");
   char* ass = strsep(&cmd1, "M");
   ass = strsep(&cmd1, " ");
//   Serial.println(ass);
   int aaa = atoi(ass);
//   Serial.println(aaa);
   return aaa;
   int v = cmdNumber("M1001 ");
   Serial.println(v, DEC);
I get 0 in my port monitor. If I uncomment Serial.println(aaa) everything goes fine and I get 1001. What the hell is wrong?  :0
AWOL
char* cmd1;
   strcpy(cmd1, cmd);
Dangerous.
Don't do it.
Raptor5
Even if I don't, still not working )
holmes4
If you want to return ass create it on the heap not the stack. The stack may be over written. Or just make it global.
Raptor5
Even this is not working
   char* a = "M1001 2334 3434";
   char* a1 = strsep(&a, " ");
   Serial.println(a);
How do I create it on heap?
Arrch
Stop creating pointers to nothing and assigning it a value. If you want to store a string of chars like that you need to actually set aside space to store those characters by using an array.
Raptor5
Please, supply an example of how to do this correctly. Thanks.
Arrch
char data[] = "This data is actually stored somewhere correctly";
or if you don't know what you needs to go into it yet:
char data[10];
Raptor5
#8
Nov 17, 2012, 07:49 pm Last Edit: Nov 17, 2012, 08:18 pm by Raptor5 Reason: 1
Ok. Now how do I pass this to strsep(char **sp, char*) ?
How do I convert char array to char** ?
Tom Carpenter
The same way you did before:
&data
'data' is just a pointer to the start of an array, and in this case the array is of type char, so 'data' a char*
As a side note, when you access an element of an array, you are essentially saying 'get the value stored at the pointer to the start of the array plus some offset'. e.g.:
data[0] is the same as *data
data[1] is the same as *(data + 1)
data[2] is the same as *(data + 2)
and so on.
~Tom~
Raptor5
Yes, but compiler stops me from doing like
strsep (&data, "M");
Tom Carpenter
You may have to type cast it:
strsep ((char**)&data, "M");
or if you don't want to type cast you could do:
char data[] = "whatever";
char* ptr = data;
strsep(&ptr,"M");
~Tom~
Raptor5
