Topic: Peripheral DMA Controller (PDC) driver for SAM (Read 4398 times) previous topic - next topic
Markus_L811
Hello,
did someone take a look at this part of the SAM and did the pdc lib from the Atmel Framework port to Arduino?
I think sounds intresting to have transmitting done without the core involved.
B.R.
Markus
stimmer
Do you have a link for this (or if it is in the Arduino tree, the path)?
And is there a library for the other DMA controller (the AHB one)? I have been trying to program the DMA hardware registers directly and my head just exploded :smiley-eek-blue:
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
Markus_L811
Install Atmelstudio 6 and the latest Framework, if you look at the "LIN_MNGT_EXAMPLE1" from the asf there you find some files specialy the pdc.h and .c
cmaglie
Look at the Audio library for an example of use of PDC. (in this case it controls the DAC output, and the output timing is clocked using a Timer)
Note that PDC is a sort of DMA "for-peripherals" and is waaaaaay simpler to use than the more powerful AHB.
https://github.com/arduino/Arduino/tree/ide-1.5.x/hardware/arduino/sam/libraries/Audio
Btw, I see a lot of developers interested in a general Arduino API for DMA, this is a hot topic, and it should be discussed in the developer list.
C
C.
