Topic: Random() (Read 3918 times) previous topic - next topic
Coding Badly
There seems to be a few other discussions happening here...
Which now ends.  Any mention of the off-topic subject "true random" will be removed from this thread.  Either help @iluvplanes or move along.
iluvplanes
Thanks for your help, @Coding Badly. It's greatly appreciated.
iluvplanes
Let me give it a try:
code...
A little bit tighter.
@dhenry, Thanks for your help!
iluvplanes
From your code, it appears that you can flash an LED multiple times in the cycle--just not twice in a row, and that within a cycle it is ok if an LED doesn't flash at all. If not, then Nick's shuffle approach is the way to go.
Thanks for pointing that one out, Pat.
I fixed it, so here's the edited part.
Code: [Select]
//The third LED
while (randNumber1 == val || randNumber1 == val2)  {
    randNumber1 = random(2,6);
//The fourth LED
while (randNumber1 == val || randNumber1 == val2 || randNumber1 == val3) {
patduino
Almost there!
Be sure to "remember" the previous values - see example below for val3.
Code: [Select]
//The third LED
    val3 = randNumber1;
    // light LED here...
//The fourth LED
There are 10 types of people in the world, those who understand binary, and those that don't.
iluvplanes
Almost there!
Actually, I did that... :) I forgot to add it in my copied code. It's in the section where I light the LED
Here's the full code for LEDs 3 & 4.
Code: [Select]
  //Write to 3rd LED
  digitalWrite(randNumber1, HIGH);
  delay(700);
  digitalWrite(randNumber1, LOW);
    val3 = randNumber1;
  //Check
  //Write to 4th LED.
  delay(700);
    val = randNumber1;
dhenry
You don't really need to do any of that.
All you wanted is to randomly pick one led to light up.
So something like this will do:
Code: [Select]
  delay(700);
Run it in a loop and you will see one led lighting up.
A much better implementation is actually what I wrote earlier: you generate a random pattern and use that pattern to determine which leds will be on / off.
patduino
Excellent!  On to he next project?
iluvplanes
On to the next project it is! Or, actually, a further, more complicated continuation of this project. I'll have the details to show you soon! :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
