Loading...
Pages: 1 ... 6 7 [8]   Go Down
Author Topic: SPI interface with other board_AVR_ESK1100 or among Arduino itself  (Read 4371 times)
Offline Offline
Full Member
View Profile
Quote
Master code on Arduino
Master code on Arduino Again
Other Slave codes are:
What?
Hi..!!
I mean to say that I have tried both the way on Arduino in Master , with delay and without delay also, but still does not respond properly.
I tried all the combination of master and slave but slave is not able to send back data for multiple if conditions or multiple SPDR = data.
And AVR EVK1100 master is reading FFFFFFFFFFFFF from slave Arduino board.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You are going to have to post code for a master, and a slave, and describe what is going wrong. Not lots of codes for each. And not "does not respond properly".
We are up to page 8 and your posts are as vague as a violet.
Logged
Offline Offline
Full Member
View Profile
Ok. I apologize for this.
//Master sending data
Code:
#include <SPI.h>// include the SPI library:
#define SS_PIN   10
int command_array[] = {0x04, 0x06, 0x08, 0x0A};
int returned_data[4];
  pinMode (SS_PIN, OUTPUT);// set the spi_data_pin as an output:
  SPI.begin();
  SPI.setDataMode(SPI_MODE2);
  SPI.setClockDivider(SPI_CLOCK_DIV64) ;
  SPI.setBitOrder(LSBFIRST);
    digitalWrite(SS_PIN,LOW);
    SPI.transfer(command_array[0]);       // send command
    //delay(1);                             // give the slave some time
    returned_data[0] = SPI.transfer(0);   // get response
    digitalWrite(SS_PIN,HIGH);
    //delay(1);
    SPI.transfer(command_array[1]);
    returned_data[1] = SPI.transfer(0);
    //delay(1);
    SPI.transfer(command_array[2]);
    returned_data[2] = SPI.transfer(0);
    //delay(1);
    SPI.transfer(command_array[3]);
    returned_data[3] = SPI.transfer(0);
    Serial.print (returned_data[0]);
    Serial.print (',');
    Serial.print (returned_data[1]);
    Serial.print (',');
    Serial.print (returned_data[2]);
    Serial.print (',');
    Serial.println (returned_data[3]);
Slave code for sending back data:
Code:
//Slave Code
#include "pins_arduino.h"
#include <SPI.h>
#define SS 10
byte c;
int m, n ;
void setup (void)
  // have to send on master in, *slave out*
  pinMode(MISO, OUTPUT);
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode (SPI_MODE2);
  // turn on SPI in slave mode
  SPCR |= _BV(SPE);
  // turn on interrupts
  SPCR |= _BV(SPIE);
 // disable timer interrupts
  TIMSK0 = 0;
}  // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
  c = SPDR;
  if(c == 0x04)
  SPDR = 0x01;
  else if(c == 0x06)
  SPDR = 0x02;
  else if(c == 0x08)
  SPDR = 0x03;
   else if(c == 0x0A)
  SPDR = 0x07;
 SPDR = 0;    // what to return to the master
}  // end of interrupt service routine (ISR) SPI_STC_vect
void loop (void)
}  // end of loop
This combination of Master and Slave code I have tried but Slave is not able to send back data to Master, I have observed in Oscilloscope MISO is not having data. What could be the reason.
« Last Edit: November 19, 2012, 05:00:46 am by ranjeetray » Logged
Pages: 1 ... 6 7 [8]   Go Up
Print
Jump to:
