Topic: Reading a txt file (Read 735 times) previous topic - next topic
Crebsyn
Ok so I am trying to read a txt file from the SD card (the file was written from the arduino and moved to a different directory) I am using the code below to convert the # but I can see I am getting Line feed and Carriage return #'s(-35, -38). How should I correct this? The # should be 259
Thank you for your help.
Reading Speed File
10000.00
2.00
5.00
9.00
-35.00
-38.00
25512.00
0.00
void AvgspeedR() {
  enableSPI();
  char AvgSR[27];
  sprintf(AvgSR, "/Read/Speed/speed%03d.txt", B+39);
  File myFile1 = SD.open(AvgSR);
  if (myFile1)
    Serial.println("Reading Speed File");
    float decade = pow(10, (myFile1.available() - 1));
    Serial.println (decade);
    while(myFile1.available())
     float temp3 = (myFile1.read() - '0');
     Serial.println (temp3);
     Matchspeed = temp3*decade+Matchspeed;
     decade = decade/10;
  Serial.println (Matchspeed);
  Matchspeed = 0;
  myFile2.close();
  disableSPI();
johnwasser
In general the way to read numbers one character at a time is:
    int digit;
    int total = 0;
    while (true)
        if (myFile1.available() == 0)
            break;
        digit = myFile1.read();
        if (digit == '\n' || digit == '\r')
            break;
        total = total * 10 + (digit - '0')
Crebsyn
Thank you, this works. I will have to spend some time figuring out how it works next.
