Loading...
Pages: [1]   Go Down
Author Topic: looking for a super source driver chip any ideas?  (Read 425 times)
Offline Offline
Newbie
View Profile
Hi guys im looking for a super source driver than can source 500ma each channel
and 8 outputs
just like the M54564P
im looking for a source driver than drive 500mA per output channel.
is there any other chips with similar functions such as this one?
« Last Edit: November 17, 2012, 10:03:48 pm by jhtran » Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Ti TPIC6B595 is, I think what you want. I've enclosed the data sheet.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
TPIC6x595 family only goes up to 350mA/channel for 8 channels with the TPIC6A595, and I imagine good heat sinking.
It looks to me like the same capability as the M54564p, 350mA/channel, but as a shift register.
http://www.ti.com/lit/ds/symlink/tpic6a595.pdf
I think what you want is ULN2803 for straight buffering.
http://www.ti.com/lit/ds/symlink/uln2803a.pdf
http://pdf1.alldatasheet.com/datasheet-pdf/view/129490/MITSUBISHI/M54564P.html
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Those aren't source drivers, they are sink drivers.  Why not parallel up outputs from two M54564P's
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
I don't know of any  P-channel MOSFET arrays, which is what you really need for those current amounts.
Allegro makes the UDN2891A-T that will source 500mA.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?freeText=udn2981&langId=-1&storeId=10001&productId=1762681&search_type=jamecoall&catalogId=10001&ddkey=http:ParametricXmlView
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
.. but you'd better not drive more than one channel at a time, because the saturation voltage drop will enough to probably overheat the package even if you drive just two channels @ 500mA.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Anaheim CA.
Offline Offline
Edison Member
View Profile
A quick review of the data sheet's first page revealed this...  (I attached the data sheet for the ULN2891)
Quote
The suffix ‘A’ (all devices) indicates an 18-lead plastic dual in-line
package with copper lead frame for optimum power dissipation. Under
normal operating conditions, these devices will sustain 120 mA continuously
for each of the eight outputs at an ambient temperature of +50°C and a supply
of 15 V.
The 500 Ma limit is for one channel driven and is a Max current rating.
@ Crossroads, I stand corrected it was the current limit that I remembered... Not the average current for any one channel.
Unfortunately I didn't read the data sheet before I jumped the gun and posted bad information.
The TPIC6B595 is only good for 150 mA continuous current for all 8 outputs driven at the same time.
Bob
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Agree with all comments.
Someone really need to come out with a multi-channel P-channel MOSFET array chip for sourcing current.
The biggest I've seen is 4 channel
http://www.digikey.com/product-detail/en/ALD1107PBL/1014-1014-ND/2414290
and the Rds is awful, 180 ohm.
I think I'd go with discrete p-channel mosfets
http://www.digikey.com/product-detail/en/FQP17P06/FQP17P06-ND/965348
this one seems a good compromise of  pretty low Rds, low cost, for a standard part (12V, use an open collector/open drain driver in front of it to turn it on,  or a shift register like TPIC6x595 (6A, 6B, 6C, 6D from avnet.com, compare prices))
Or this one
http://www.digikey.com/product-detail/en/NDP6020P/NDP6020P-ND/1055922
if you're sourcing current from 5V and and control it directly from ATmega outputs, of shift register like 74HC595.
Logged
Offline Offline
Edison Member
View Profile
Quote
You may want to look into dc/dc converters: they can be easily configured to produce your desired current levels and they are much more efficient than linear solutions, especially at that kind of current levels.
All you do is to use a resistor to program the desired current levels.
Logged
Offline Offline
Edison Member
View Profile
If you don't mind smd devices, using individual mosfets would probably work well
Jw, what's the application? If its fast switching there may be other considerations
Logged
Pages: [1]   Go Up
Print
Jump to:
