Pages: [1] 2   Go Down
Author Topic: Bluetooth Shield Problem.. pls help!  (Read 820 times)
Im currently using a gizduino V.3 (http://www.e-gizmo.com/KIT/Gizduino.html).. it's working fine..
but when i plug the bluetooth shield- EGBT-04S slave only (http://www.e-gizmo.com/KIT/BLUETOOTH%20SHIELD.html) to the gizduino, the shield wont work.. The LED1 (green) and LED2 (red) wont blink..
i uploaded the code slave.pde to test the shield.. but nothing seems to work..
any help guys?..  plsss...  smiley-roll
any help guys?..  plsss...    smiley-cry
Brisbane, Australia
Hi
How are you powering it, just via the Arduino?  And how is the power selector (S2 jumper near the power jack) set?  Is there a chance you have it set to expect external power?
Cheers ! Geoff
Yes, just by the gizduino(connected to my pc).. do i need to use an external dc supply for the shield?.. how do i change the setting?.. im really new with this stuff..  smiley-cry
i actually tried using an external dc supply for my bluetooth shield (9V).. but it still didn't work..
Brisbane, Australia
I don't own one of these, but reading from the schematic in the user manual you need to have a jumper either between the leftmost pin and middle one (on S2) to tell it to use the external power; or between the rightmost pin and the middle one to tell it to take 5V power from the Arduino.
Curiously the photo there shows no jumper on S2 at all, but there's nothing in the schematic to indicate that would work.
Cheers ! Geoff
wow! it actually worked!.. thanks strykeroz!..
i'll just be posting.. if i'll encounter another problem..
a big thanks bro..  smiley smiley
I got the green LED blinking.. but still could not get it to work.. I need to get the red led to blink and green led to be steady so that the BT shield will be on SLAVE mode..
when i.uploaded the slave.pde without the shield, it will complete uploading.. but will not get the BT shield to work..
and when i uploaded the slave.pde with the shield.. I got the error: avrdude: stk500_getsync(): not in sync: resp=0x49
what should I do?
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
what is on the other end of that BT connection, PC, phone, what are you trying to control it from?
Note: the shield does need to be off the board inorder to upload the code.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
An android phone.. trying to communicate to the BT shield using android..
ah, so.. i need to upload the code before putting the shield on the arduino.. tnx..
but, it still wont work?... smiley-sad
i used the codes found in http://www.seeedstudio.com/wiki/index.php?title=Bluetooth_Shield..
is it applicable with my BT shield?..
Norfolk UK
I don't have the shield like you have but the module I bought http://www.hobbytronics.co.uk/wireless/bluetooth/bluetooth-module looks similar. It just plugs into arduino 5V, GND, RX & TX and no need for any special arduino software. Just pair computer with it and open terminal window and it just works when arduino does Serial.print.
how can i pair it with my android phone?.. i tried but the BT shield cannot be detected.. as if it's not in slave mode yet.. the green led just keeps blinking fast..
Queens, New York
You need the MAC address of the BT module, that MAC address has to be in your android code. Also include the correct UUID.
The best way to detect the BT module would be to pair it to your computer, and get the MAC address that way or through a program call "Bluetooth chat".
« Last Edit: November 18, 2012, 11:19:43 am by HazardsMind » Logged
Melbourne, Australia
Shannon Member
Lua rocks!
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Pages: [1] 2   Go Up
