Loading...
Pages: [1]   Go Down
Author Topic: How to use second I2C?  (Read 1105 times)
USA, OH
Offline Offline
Jr. Member
View Profile
I tried using accelerometer on pins 20 & 21 but it seems like there is something wrong with the board (no, I did not use +5V anywhere).
Somewhere it is mentioned DUE has two I2C interfaces, and there are pins SCL1 and SDA1 next to AREF pin.
How I can switch to using them?
Logged
Germany
Offline Offline
Full Member
View Profile
Did you use Wire.send... and so for the I2C for the I2C on top behind Aref you need to use Wire1.send...
And by the way on SCL1 SDA1 you need Pullups about 1.5kOhm on both. SCL0 SDA0 did have them build in.
« Last Edit: November 18, 2012, 05:23:49 am by Markus_L811 » Logged
USA, OH
Offline Offline
Jr. Member
View Profile
Thanks a bunch, this works!
« Last Edit: November 18, 2012, 11:39:57 am by Stan09 » Logged
Offline Offline
Newbie
View Profile
So in summary, is this correct?
If using Pin 20 and 21:
Internal pullups are provided.
Use Wire.setup() to control these.
If using SCL1 and SDA1:
You must provide 1.5k pullup resistors
The pullup source is taken from the 3.3V pin near the RESET pin.
Use Wire1.setup() to control these.
If this is all true, then I am unable to get pins 20 and 21 working. They just stay at logic high all the time. Have I missed something? I'm just running the master code here http://arduino.cc/en/Tutorial/MasterWriter
Will this work with just one device? I am just using one device and a logic analyzer to monitor the pins.
Thanks,
Doug
« Last Edit: April 07, 2013, 06:01:07 pm by dougcl » Logged
Cookeville, TN
Offline Offline
Newbie
View Profile
Thanks,
Doug
I went ahead and used the 1.5k pullup resistors on both pairs of inputs. This worked for me. Let us know if that fixes it for you.
Logged
Pages: [1]   Go Up
Print
Jump to:
