Loading...
Pages: [1]   Go Down
Author Topic: found bug in delayMicroSeconds when called with 0;  (Read 895 times)
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
The delayMicroseconds function fails when called with a value of 0.
Although this is not done normally, it can happen when it is called with a variable which is the result of some expression/calculation.
The bug can be traced back to the if (--us ==0) statement, which causes an overflow when the param us is 0. The delay is then far longer (about 16384 micros) .
BUG seen in IDE 0.22 + 1.0.0 + 1.0.2
Find test program and patch below : NOTE the patch does not include the 1.0.2 20Mhz addition as I cannot test it .
The patched version of the delayMicroseconds() will return asap when called with 0 . This still takes about 1.2 uSec but that is way better than 16K uSec smiley
Q: can anybody confirm this bug in a 20Mhz duino?
Program to show bug
Code:
//    FILE: delayMicrosecondsBUG.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2012-11-18
// PUPROSE: test delayMicroseconds()
  Serial.println("start...");
  unsigned long m = micros();
  for (uint8_t i=0; i<100; i++)
    delayMicroseconds(0);
  Serial.println(micros()- m);
  m = micros();
    delayMicroseconds(1);
  m = micros();
    delayMicroseconds(2);
  m = micros();
  delayMicroseconds(20);
  m = micros();
  delayMicroseconds(200);
  m = micros();
  delayMicroseconds(2000);
Find below a patch for the function (for 0.22 - 1.0.0 version):
Code:
void delayMicroseconds(unsigned int us)
// calling avrlib's delay_us() function with low values (e.g. 1 or
// 2 microseconds) gives delays longer than desired.
//delay_us(us);
#if F_CPU >= 16000000L
// for the 16 MHz clock on most Arduino boards
// for a one-microsecond delay, simply return.  the overhead
// of the function call yields a delay of approximately 1 1/8 us.
//  PATCH
// if (--us == 0)
// return;
if (us < 2) return;
us--;
// the following loop takes a quarter of a microsecond (4 cycles)
// per iteration, so execute it four times for each microsecond of
// delay requested.
us <<= 2;
// account for the time taken in the preceeding commands.
us -= 2;
#else
// for the 8 MHz internal clock on the ATmega168
// for a one- or two-microsecond delay, simply return.  the overhead of
// the function calls takes more than two microseconds.  can't just
// subtract two, since us is unsigned; we'd overflow.
// PATCHED LINES
// if (--us == 0)
// return;
// if (--us == 0)
// return;
if (us < 3) return;
us -= 2;
// the following loop takes half of a microsecond (4 cycles)
// per iteration, so execute it twice for each microsecond of
// delay requested.
us <<= 1;
// partially compensate for the time taken by the preceeding commands.
// we can't subtract any more than this or we'd overflow w/ small delays.
us--;
#endif
// busy wait
__asm__ __volatile__ (
"1: sbiw %0,1" "\n\t" // 2 cycles
"brne 1b" : "=w" (us) : "0" (us) // 2 cycles
TODO: post on the issue list yet ...
« Last Edit: November 18, 2012, 05:26:17 am by robtillaart » Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Netherlands
Offline Offline
Tesla Member
View Profile
Reported as #1121 on  - https://github.com/arduino/Arduino/issues?state=open -
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
a more generic patch might work for the 20Mhz too    (values smaller than 2 are exceeded by function call overhead)
Code:
  if (us <2) return;
Logged
Rob Tillaart
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
It will be interesting to see if the arduino developers will consider this a bug or a feature as they already note the minimum value on can use will accurate results. I the reference for delayMicroseconds:
Quote
Caveats and Known Issues
This function works very accurately in the range 3 microseconds and up. We cannot assure that delayMicroseconds will perform precisely for smaller delay-times.
Lefty
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Hi Lefty,
Rationale for that statement is the fact that a function call takes approx 1 usec. Checking the param takes some clock cycles too. So before one can start to count down, too much time may have passed already (for small values). The root cause is that one is near the cpu speed.
But mapping 0 usec on 16K usec is a serious Bug - with capital B smiley-wink
For the Due which is 84(?) Mhz I expect a re-implementation for this function. However no experience yet with the Due.
Logged
Rob Tillaart
Offline Offline
Brattain Member
View Profile
Hi Lefty,
I believe there is also a minimum 4 usec step size resolution for the delayMicroseconds function as implemented in the arduio AVR platform? So it's not capable of 1 usec resolution timing delays as one might assume otherwise even at values greater then 3?
Lefty
« Last Edit: November 18, 2012, 12:30:46 pm by retrolefty » Logged
Netherlands
Offline Offline
Tesla Member
View Profile
The delayMicroseconds() implementation ends with
Code:
// busy wait
which is a tight loop decrementing the var us. So I think the timing is quite precise for values > 2.  This loop takes 4 cycles so it is executed 4 times per usec (16Mhz assumed).
The stepsize of 4 usec is the precision of the micros() function so if you want to measure time smaller than 4 usec you need a HW timer solution. Can't find the link now.
Logged
Rob Tillaart
Offline Offline
Brattain Member
View Profile
Code:
// busy wait
Thanks for that.
 Yes, I was mixing up micros() with delayMicroseconds(). Put then again I'm old, so I'm allowed a certain amount of 'brain farts' per fortnight, as I continue to chase kids off my lawn.  smiley-wink
Lefty
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
The what?
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
@CB
Quote
The what?
The 1.0.2 version of wiring.c has additional code to implement this delayMicroseconds() function correctly(?) for a 20Mhz arduino.
As I do not have such a thing I cannot test it.
Clear now?
« Last Edit: November 20, 2012, 01:44:47 pm by robtillaart » Logged
Rob Tillaart
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Got it.  Thanks.
Logged
Pages: [1]   Go Up
Print
Jump to:
