Topic: wrong readings from ADXL345 (Read 4837 times) previous topic - next topic
Stan09
When I am reading accelerometer data (with my settings) from MEGA it returns just zeroes and sometimes '-1'.
This is normal, because I set it up with lowest sensitivity (16g) and accelerometer just sits on the desk.
But when I run the same code on DUE instead of '-1' I see 65535.
I wonder, does it have anything to do with different int type for DUE?
I believe this is all about that line
x = (((int)byte_buff[1]) << 8) | byte_buff[0];
Probably there is something wrong with signed integer representation. As I understand, when INT is stored in 2 bytes, then '-1' in binary would be just 16 '1'-s, but  when this number is interpreted as 4 bytes, it is equal to 65535. I am not quite good in understanding details of signed integers representation, so I might be wrong.
Any ideas?
pico
#1
Nov 18, 2012, 06:10 pm Last Edit: Nov 18, 2012, 06:12 pm by pico Reason: 1
No, you've already figured it out. All 16 bits set in a two byte signed integer represents -1; in a 4 byte signed integer, the lower 16 bits set represents 65535 (-1 would be represented by all 32 bits set). The highest bit in a signed integer holds the sign of the number, + or -ve; the rest of the bits hold the actual value. To change the sign of an integer, the rule is to change all the zero bits to ones, and all the one bits to zero. That produces what is called the "one's complement". And then add one to that (using unsigned overflow arithmetic). That produces the "two's complement". If you are curious, you can read why it is represented this way here:
http://en.wikipedia.org/wiki/Two%27s_complement
More practically, for your problem, a quick fix would be to declare the offending 32 bit int as int16_t in the Due code. Then you'll be working with a 16 bit signed int on both platforms.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
Stan09
Hurray, we did it!
It works!
But I wonder, am I the only one who has noticed that?
Does not this mean that f.e ADXL345 library (and probably, many others?) must be corrected for DUE?
pico
It certainly does.
Markus_L811
Hurray, we did it!
It works!
Hey Stan,
would you post your complete sketch, so we can see what you have done.
Pullup
how should I adjust the following code to run it on a due?
(ADXL 345 via SPI)
//Add the SPI library so we can communicate with the ADXL345 sensor
#include <SPI.h>
//Assign the Chip Select signal to pin 10.
int CS=10;
//This is a list of some of the registers available on the ADXL345.
//To learn more about these and the rest of the registers on the ADXL345, read the datasheet!
char POWER_CTL = 0x2D; //Power Control Register
char DATA_FORMAT = 0x31;
char DATAX0 = 0x32; //X-Axis Data 0
char DATAX1 = 0x33; //X-Axis Data 1
char DATAY0 = 0x34; //Y-Axis Data 0
char DATAY1 = 0x35; //Y-Axis Data 1
char DATAZ0 = 0x36; //Z-Axis Data 0
char DATAZ1 = 0x37; //Z-Axis Data 1
//This buffer will hold values read from the ADXL345 registers.
char values[10];
//These variables will be used to hold the x,y and z axis accelerometer values.
int x,y,z;
void setup(){
  //Initiate an SPI communication instance.
  SPI.begin();
  //Configure the SPI connection for the ADXL345.
  SPI.setDataMode(SPI_MODE3);
  //Create a serial connection to display the data on the terminal.
  //Set up the Chip Select pin to be an output from the Arduino.
  pinMode(CS, OUTPUT);
  //Before communication starts, the Chip Select pin needs to be set high.
  digitalWrite(CS, HIGH);
  //Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
  writeRegister(DATA_FORMAT, 0x01);
  //Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
  writeRegister(POWER_CTL, 0x08);  //Measurement mode
void loop(){
  //Reading 6 bytes of data starting at register DATAX0 will retrieve the x,y and z acceleration values from the ADXL345.
  //The results of the read operation will get stored to the values[] buffer.
  readRegister(DATAX0, 6, values);
  //The ADXL345 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
  //The X value is stored in values[0] and values[1].
  x = ((int)values[1]<<8)|(int)values[0];
  //The Y value is stored in values[2] and values[3].
  y = ((int)values[3]<<8)|(int)values[2];
  //The Z value is stored in values[4] and values[5].
  z = ((int)values[5]<<8)|(int)values[4];
  //Print the results to the terminal.
  Serial.print(x, DEC);
  Serial.print(',');
  Serial.print(y, DEC);
  Serial.print(',');
  Serial.println(z, DEC);
  delay(10);
//This function will write a value to a register on the ADXL345.
//Parameters:
//  char registerAddress - The register to write a value to
//  char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
  //Set Chip Select pin low to signal the beginning of an SPI packet.
  digitalWrite(CS, LOW);
  //Transfer the register address over SPI.
  SPI.transfer(registerAddress);
  //Transfer the desired register value over SPI.
  SPI.transfer(value);
  //Set the Chip Select pin high to signal the end of an SPI packet.
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
//  char registerAddress - The register addresse to start the read sequence from.
//  int numBytes - The number of registers that should be read.
//  char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, char * values){
  //Since we're performing a read operation, the most significant bit of the register address should be set.
  char address = 0x80 | registerAddress;
  //If we're doing a multi-byte read, bit 6 needs to be set as well.
  if(numBytes > 1)address = address | 0x40;
  //Set the Chip select pin low to start an SPI packet.
  //Transfer the starting register address that needs to be read.
  SPI.transfer(address);
  //Continue to read registers until we've read the number specified, storing the results to the input buffer.
  for(int i=0; i<numBytes; i++){
    values[i] = SPI.transfer(0x00);
  //Set the Chips Select pin high to end the SPI packet.
Code from: http://sparkfun.com/tutorial/ADXL/ADXL345_Basic.pde
Stan09
(ADXL 345 via SPI)
#include <SPI.h>
int CS=10;
char values[10];
int x,y,z;
void setup(){
  SPI.begin();
void loop(){
  Serial.print(',');
  Serial.print(',');
  delay(10);
//Parameters:
//Parameters:
I would just change
int x,y,z;
to
int16_t x,y,z;
Pullup
I tried this, but output looks like:
-1,-1,-1
-1,-1,-1
-1,-1,-1
0,0,0
0,0,0
16191,16191,16191
-1,-1,-1
-1,-1,-1
-1,-1,-1
-1,-1,-1
Stan09
well, since it is not 65535, 65535,65535 but -1,-1,-1 - this proves it is not 'int' format, this is something else. Might be bad contact somewhere, f.e. Try regular Arduino with the same sketch?
