Topic: Rail to move a camera at precise speed? (0.25 meters per second at 1mm accuracy) (Read 3851 times) previous topic - next topic
mdrejhon
Hello,
This is for a scientific experiment on exact motion blur measurements.
I am trying to construct an Arduino-driven rail that can move a small camera sideways at a precise speed: 0.25 meters per second (about 10 inches per second).
(I'll be using a CHDK-modified arduino-triggerable Canon camera)
These are my requirements:
- I'm taking 1/10th second camera exposures while the camera is moving sideways
- So, I only need +/- 1mm precision for only 1/10th second.
- Inaccuracy during acceleration and deceleration is okay.
- Rail can be short, e.g. half a meter long -- just as long as I achieve precise 0.25 meters per second (controllable in approx mm increments if possible) for the 1/10th second interval I need to take the photo
How would I construct a rail?   I could take apart an inkjet printer, mount the camera on top of the cartridge holder, and use the Arduino to move the inkjet head platform (moving the camera) at a precise speed.  Any alternatives?  Ideas?
johnwasser
I'd use a nut on a threaded rod and turn the threaded rod with a stepper motor.  If you use a metric threaded rod the calculations will be fairly easy.  A course threaded rod (possibly double or triple start) might be necessary if you can't get the stepper spinning fast enough.
zoomkat
Is there a start/stop requirement for the camera at each position along the rail, or can the camera continue to move at the specified speed? If the camera can keep moving, then a continously moving surface like a conveyor belt or the cable on a ski lift might be fairly simple to setup.
mdrejhon
I don't care about start/stop details, as long as I can keep resetting it and repeating. What I need is a photograph successfully taken automatically (Arduino-controlled shutter, Canon CHDK fimware or modified shutter button) at an approximately exact horizontal position, while the camera is horizontally moving at an accurately measurable speed.  The start/stop can be as messy or continuous; but ideally, I'd like something that fits on a desk, no more than for feet long.  It also needs to be transportable to different sites, so I'll mount all of this on a portable platform.
Essentially, camera starts moving, accelerates, [BEGIN precision requirement] then takes a picture for 1/10th second [END precision requirement], then camera decelerates to a stop.  I only need one picture, but when the shutter is open, the precision requierments apply.
Here are my preferred requirements:
(1) Must fit on a desk (ideally less than 1 meter long (1 to 3 feet long) maximum 4 feet long. Less than 1 feet deep).
(2) Speed control: 1mm per second increments, up to at approx ~300mm per second.  (more is desirable -- but not needed now)
(3) Speed error: +/- 1mm per second error (@250mm per second)
(4) Positioning error: +/- 1 centimeter (Manual shutter timing fine-tuning should be manageable)
(5) Amount of time the precision is required: 1/10th second (macro mode)
(6) Moving mass required: Typical point-and-shoot camera (1/10sec allows use of lightweight camera w/manual exposure ability)
Acceptable precision degradations, if certain parameters are expensive/difficult to meet:
(2b) Speed control: 5mm per second increments (= 0.5mm per second difference during 1/10sec exposure)
(3b) Speed error: +/- 10mm per second (= 1mm error during 1/10sec exposure)
(4b) Positioning error: +/- 5 centimeter (I can do multiple attempts until subject matter is fully in the frame)
A conveyor belt?  That could work, too.  I'd put the camera on the conveyor surface, even duct tape it down, and press a button to start moving the belt (letting logic and triggers do the work for me).
I have a discarded inkjet printer too, just in case I use its ink cartridge platform as my camera platform.  However, I'm open to ideas of easier-to-build solutions that fully meets my accuracy requirements, as my spare hobby build time is limited.
[P.S. If someone is willing to build this for me, there's some money in it for you, above and beyond parts cost.  I will give you some publicity in my blog, if you open-source the build instructions.]
sbright33
I can do this!  I can send you a picture of the slider.  The coding is easy.  After you see what I've built, you can tell me how much this setup is worth to you.
MarkT
If you take a 0.1s exposure at 0.25m/s the motion blur will be 2.5cm - I don't see what needs measuring? (image stabilization?)
Have you considered mounting an LED on a rotating wheel driven by a stepper motor at a precise rate and seeing the blur of that?
scottyjr
I'm interested in what you have done. Would you post pictures please? - Scotty
