Loading...
Pages: [1]   Go Down
Author Topic: nanosecond delay functions - playing with volatile  (Read 953 times)
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Today I played with the delayMicroseconds() function - http://arduino.cc/forum/index.php/topic,132983.0.html -  It seems to be difficult to get delays of 1 and 2 usec right. So I tried to make a function that delayed for exactly 1 usec and started experimenting with the volatile keyword in (for me) new ways.
This way I "fabricated" 4 functions:
- delay125ns();
- delay250ns();
- delay500ns();
- delay1000ns();
The timings are approx within 1% tested on a 16Mhz Duemillanove. I tested these functions by running them in a loop, first with one call , and then a second loop with 2 calls, so the difference is the time used by the functions as the loop overhead is subtracted too.
Note: There are better ways to implement these functions - using asm("nop"); - but this was just fun! smiley
The functions:
Code:
void delay125ns()
  volatile uint8_t x=0;
  return;
void delay250ns()
  volatile int x=0;
  return;
int delay500ns()
  volatile int x=0;
  return x;
int delay1000ns()
  volatile int x = 0;
  volatile int y = 0;
  return x+y;
// profi way to implement such delay functions
void d250ns()
  asm("nop");
  asm("nop");
  asm("nop");
  asm("nop");
The testprogram with functions:
Code:
  Serial.println("start...");
  unsigned long m;
  unsigned long n;
  Serial.println("delay125ns");
  m = micros();
  for (unsigned int i=0; i<16000; i++) delay125ns();
  m = micros() - m;
  n = micros();
    delay125ns();
    delay125ns();
  n = micros() - n;
  Serial.print("Extra 1000 calls take: ");
  Serial.println((n-m)/16);
  Serial.println("delay250ns");
  m = micros();
  for (unsigned int i=0; i<16000; i++) delay250ns();
  m = micros() - m;
  n = micros();
    delay250ns();
    delay250ns();
  n = micros() - n;
  Serial.println("delay500ns");
  m = micros();
  for (unsigned int i=0; i<16000; i++) delay500ns();
  m = micros()- m;
  n = micros();
    delay500ns();
    delay500ns();
  n = micros()- n;
  Serial.println("delay1000ns");
  m = micros();
  for (unsigned int i=0; i<16000; i++) delay1000ns();
  m = micros() - m;
  n = micros();
    delay1000ns();
    delay1000ns();
  n = micros() - n;
void delay125ns()
  return;
void delay250ns()
  volatile int x=0;
  return;
int delay500ns()
  volatile int x=0;
  return x;
int delay1000ns()
  volatile int x = 0;
  volatile int y = 0;
  return x+y;
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Does the presence or absence of the return statement make any difference? I typically do not include a return statement in a function of type void, since it will return anyway.
Logged
Italy
Offline Offline
Brattain Member
Don't know what I do
View Profile
I think that robtillaart has based its counting mechaninsm on the declaration of variables and the usage of return statement.
If you look at his code, every function has a different combination of variable declaration and value returned.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
You mean the voids returned by delay125ns(), delay250ns(), and d250ns()?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
That's how I took it. A dump of the generated object code would show the actual instructions generated that make up the specific delay values sought.
Lefty
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
FYI, I focused more on the initialization of the volatile vars, and sought different ways to add cycles. Without volatile the compiler optimizes the functions away.
I will look if I can do a dump of the assembly/obj tonight but the forum is soooo sloooow at the moment.
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
For those interested, the output of objdump -d -S testDelayNanoSeconds.cpp.o is in the zip file attached.
have fun smiley-wink
Logged
Rob Tillaart
Italy
Offline Offline
Brattain Member
View Profile
Interesting  smiley-wink
Logged
Pages: [1]   Go Up
Print
Jump to:
