Loading...
Pages: [1] 2   Go Down
Author Topic: Pin output toggling error.......signal tearing?  (Read 340 times)
Offline Offline
Newbie
View Profile
I'm trying to just toggle the output pin several times to get desired timing signal. However I'm getting some errors in output.
Few signals/toggles get missing on random interval. Is this called Signal Tearing?
How to fix it?
Please advice.
Code:
#define NOP  __asm__ __volatile__("nop\n\t")
   DDRB = DDRB | B00111111; // sets Arduino pins 8 to 13 as outputs, pins GND & AREF are unchanged
   PORTB = 0;
   while(1)
    for(int j=0;j <5; j++)
      for(int i=0;i<24; i++)
        PORTB = 1;
        NOP;
        NOP;
        NOP;
        NOP;
        PORTB = 0;
        NOP;
        NOP;
        NOP;
        NOP;
   PORTB = 0;
   delayMicroseconds(200);
Output where you can see some signals missing for about 6.4uSec
http://i49.tinypic.com/6zwps4.jpg
Thanks
« Last Edit: November 18, 2012, 03:26:05 pm by DirtyBits » Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
The timer interrupt fires every 1.024 mS which would stop your loop temporarily. If you want a proper signal use the hardware timers, not a timed loop. Examples here:
http://www.gammon.com.au/forum/?id=11504
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
There is also a small gap just after where you have 40 uS on the screenshot (which is after 24 pulses) which would be where the loop of 24 ends.
Logged
Offline Offline
Newbie
View Profile
true
..1st let me refer to the link you send...brb
Logged
Offline Offline
Newbie
View Profile
Thanks a lott Nick..you are a super star!!
I tried to scan through the whole Timer and Interrupt topics...understood few bits and pieces but finally found out that
cli (); is needed to Disable Interrupt flag. I put that after "While" in the loop and it works!!
Code:
while(1)
cli ();
But the question is would that affect any other Interrupt routine in the "While" loop?? i.e. if I'm using  Serial.read function then??
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
If you turn off interrupts you won't be getting any serial reads (or writes) and the timer functions will return incorrect time.
You are better off generating pulses in hardware.
Logged
UK
Offline Offline
Tesla Member
View Profile
would that affect any other Interrupt routine ...
If you disable interrupts then you disable all interrupts.
Nick's suggestion to use a hardware timer to do the fixed frequency output did not rely on disabling interrupts and seems like a much better approach to take.
Logged
Offline Offline
Edison Member
View Profile
Quote
It doesn't disable interrupt flags: it disable interrupt execution. The flags will be set as they otherwise would be, except that they don't trigger isrs anymore.
Before you disable it, think hard if you have to. If your pulses needs to be generated absolutely as you had written, without interruption, you then have no choice but to disable interrupts.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Even then there will be glitches at the end of loops, as I pointed out above. He has "no choice" but to use the hardware timers if he wants glitch-free pulses.
What frequency are you after? 1 MHz? This sketch does that, nice and simple:
Code:
const byte LED = 3;  // Timer 2 "B" output: OC2B
const long frequency = 1000000;  // 1 MHz
  pinMode (LED, OUTPUT);
  TCCR2A = _BV (WGM20) | _BV (WGM21) | _BV (COM2B1); // fast PWM, clear OC2A on compare
  TCCR2B = _BV (WGM22) | _BV (CS20);         // fast PWM, no prescaler
  OCR2A =  (F_CPU / frequency) - 1;          // zero relative
  OCR2B = ((OCR2A + 1) / 2) - 1;             // 50% duty cycle
  }  // end of setup
  // do other stuff here
Glitch-free output:
Plus you are free to do whatever you want in the main loop, interrupts, serial send/receive, whatever.
Logged
Offline Offline
Edison Member
View Profile
If you have to protect the transmission, you may want to think what it is that you are trying to protect: you can protect the pulse width (high or low, or high and low); you can protect every 8 pulses; or you can protect all 24 pulses.
That will determine where / when  you disable / re-enable the interrupts.
The key is to minimize the duration of disabling them.
Logged
UK
Offline Offline
Tesla Member
View Profile
I disagree. Nick Gammon has already demonstrated a far better approach which does not require or rely on disabling interrupts. A general rule I try to follow is to use interrupts only where necessary, and when using interrupts disable them only where necessary. In this case, neither the use of interrupt nor the disabling of interrupts are necessary.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Nick;
 That's a very impressive application of a timer. I have a few questions:
1. Can the OCR2A&B registers be changed 'on the fly' to other values without having to do anything else?
2. What would the max and min frequencies be on a standard 16 Mhz board with retaining @ 50% duty cycle?
3. What would be the commands to stop the timer at any time, and to restart it at any time.
Sure seems like this could be made into a nice simple general purpose function clock generator?
Lefty
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
Yes they can. They would take effect next cycle. If you are going smaller it might be best to stop the clock in case it overshoots the new limit, and then start it again.
Quote
With no prescaler:  62.5 KHz to 4 MHz.
With a prescaler of 8: 7813 Hz to 1 MHz.
And so on. (With no prescaler it should go to 8 MHz but I got artifacts doing that).
Quote
You would turn off the clock source, eg.
Off:
Code:
  TCCR2B = 0;         // clock stopped
On:
Code:
If you just want a 50% duty cycle some of the other modes (like CTC) might be better. This one uses both "sides" of the timer. I did a bit of copy/paste on that one. <grin>
Logged
Offline Offline
Newbie
View Profile
Code:
  }  // end of setup
Glitch-free output:
Thanks Nick!
Just woke up  smiley-wink
I need pulses of min 250nS or max 400ns. I need to learn how to use your approach though.
Logged
Offline Offline
Newbie
View Profile
Quote
yes it disables all Interrupts...
Logged
Pages: [1] 2   Go Up
Print
Jump to:
