Loading...
Pages: 1 [2]   Go Down
Author Topic: connection diagram order to arduino lcd j12864 - pedido de diagrama de coneccion  (Read 1623 times)
Offline Offline
Newbie
View Profile
i have the same problems! I have an arduino mega and also de graphic lcd j12864 and i don't know how to connect them! I downloaded the ug8 library but i think my problem is hardware. I just don't know how to connect the lcd to the arduino.
Logged
Germany
Offline Offline
God Member
If you believe something is right, you won't see what's wrong (David Straker).
View Profile
PSB to GND
RST to Digital Pin 5
E to Digital Pin 4
R/W to digital pin 3
RS to digital pin 2
Other pins as described in the datasheet or the controller manual of the ST7920.
Then use:
Code:
U8GLIB_ST7920_128X64 u8g(4, 3, 2, U8G_PIN_NONE, 5 );
Pin numbers above are only suggestions, you may use any valid digital pin.
Oliver
Logged
Offline Offline
Newbie
View Profile
thanks. I did what you say, but i still get nothing in the lcd.
I connected the pins as you said, also de vcc and ground, but the lcd didn't turn on.
I'm using the ug8 library and trying to do the example "Hello world"... I still get nothing and i'm getting angry! ja
thanks for your support!
Logged
Germany
Offline Offline
God Member
View Profile
Maybe you can post a picture of your setup, so that we can have a look at it.
Oliver
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
