Topic: What do you think of these odd cheap displays from American Science and Surplus? (Read 2571 times) previous topic - next topic
JoeN
A VFD display for a buck.  I have already figured out the pinouts for these LEDs, all work fine.  The X/O display has two segments for the X's (/ and \) and four for the O's (N, S, E, and W crescents.)   Everything I tried worked.  Haven't done the VFD yet but they look like they are new condition, never used.
I will never ask you to do anything that I wouldn't do myself.
johnwasser
I like those 3-digit 7-segment displays.  I'd buy a dozen just to have handy.
Not so sure about the X-in-O displays.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
JoeN
I bought (left to right) 10, 10, 5, 5, mostly on account of how little they all cost.
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
JoeN
Arduino: noughts and crosses game!
That was what I was thinking but there is a practical problem with the displays being 2x1 instead of 3x1 which is there is no possible way to fit them into a 3x3 board, so I guess you go with a 4x4 board which is less common around here.  One possibility could be that each move is half an O or half an X because the segments are evenly divisible but I am not sure if that would make the game better or worse.
I am even more interested in that VFD.  I forgot that the filament driver is usually low voltage AC so I have to make a power supply to do that and start testing it out.
Osgeld
you can arrange them
121
122
1212
and have that one sticking out to indicate who's turn it is with 5 units
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
RanTalbott
The "XO" displays could make an interesting binary clock display: use the crescents for the low-order 4 bits, and the bars for the 3 high-order ones.
You could also use them to make an animated gauge by "spinning" it at a variable rate to show magnitude.
