Topic: Controlling multiple servos with different pushbuttons (Read 1 time) previous topic - next topic
fearthisbeard
So I am trying to have 3 different servos each connected to a separate pushbutton move whenever the pushbutton they are assigned to is pressed. Along with that a LED will light up. I have managed to make it work fine with one pushbutton and servo but am running into issues when trying to add more. The code I have tried with two pushbuttons and servos kind of works but the servos do not move independently of each other, no matter which button is pressed both servos move.
Code: [Select]
#include <Servo.h>
Servo myservo;                // create servo object to control a servo
Servo myservo2;               // create servo object to control a servo
const int buttonPin = 2;      // the pin that the pushbutton is attached to
const int ledPin    = 5;      // the pin that the LED is attached to
const int buttonPin2 = 3;     // the pin that the second pushbutton is attached to
int buttonState     = 0;      // current state of the button
int lastButtonState = 0;      // previous state of the button
int ledState        = 0;      // remember current led state
int pos             = 0;      // variable to store the servo positions
  myservo.attach(8);          // attaches the servo on pin 8 to the servo object
  pinMode(buttonPin, INPUT);  // initialize the button pin as a input
  pinMode(ledPin, OUTPUT);    // initialize the button pin as a output
  myservo2.attach(9);          // attaches the servo on pin 9 to the servo object
  pinMode(buttonPin2, INPUT);  // initialize the button pin as a input
  buttonState = digitalRead(buttonPin); // read the pushbutton input pin
    if (buttonState != lastButtonState) // compare buttonState to previous state
      if (buttonState == 1)
        if(ledState == 1)
            ledState = 0;
            for(pos = 0; pos <= 90; pos += 5)    // goes from 0 degrees to 90 degrees
            {                                    // in steps of 5 degrees
            myservo.write(pos);                  // tell servo to go to position 'pos'
            delay(15);        // waits 15ms for the servo to reach the position
            ledState = 1;
            for(pos = 90; pos >= 1; pos -= 5)    // goes from 90 degrees to 0 degrees
    lastButtonState = buttonState; // remember the current state of the button
  // turns LED on if the ledState =1 or off if ledState = 0
  digitalWrite(ledPin, ledState);
  myservo.write(pos);          // goes from 0 degrees to 90 degrees
  delay(20);
   buttonState = digitalRead(buttonPin2); // read the pushbutton input pin
        if(ledState == 1)
            ledState = 0;
            myservo2.write(pos);                  // tell servo to go to position 'pos'
            ledState = 1;
  myservo2.write(pos);          // goes from 0 degrees to 90 degrees
  delay(20);
Any suggestions?
Thanks!
guix
#1
Nov 19, 2012, 08:52 am Last Edit: Nov 19, 2012, 08:59 am by guix Reason: 1
Hello and welcome,
What if you create new variable lastButtonState2 ? Since you use lastButtonState for both buttons it might make troubles... :)
PaulS
Why is the variable that defines the direction to move the servo called ledState?
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
