Loading...
Pages: [1]   Go Down
Author Topic: problem with comparators  (Read 137 times)
Offline Offline
Newbie
View Profile
Hi, im making a code with the dht11 sensor, lcd to see the data and comparators with the humidity and temperature. My goal is to reach some basic comparation like if the humidity is lower than 50% then turn on a led and if is higher than 70% turn on another lead. I want to mix the codes
this is the lcd + dht11
Code:
#include <LiquidCrystal.h>
#include <<span class="domtooltips">dht11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.h>
<span class="domtooltips">dht11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span> <span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>;
#define DHT11PIN 6
double DPC;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 2, 3, 5, 4);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
Serial.println("<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span> TEST PROGRAM ");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT11LIB_VERSION);
int chk = <span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.read(DHT11PIN);
Serial.print("Read sensor: ");
switch (chk)
case 0: Serial.println("OK"); break;
case -1: Serial.println("Checksum error"); break;
case -2: Serial.println("Time out error"); break;
default: Serial.println("Unknown error"); break;
Serial.print("Humidity (%): ");
Serial.println((float)<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.humidity, DEC);
Serial.print("Temperature ( C): ");
Serial.println((float)<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.temperature, DEC);
Serial.print("Temperature ( F): ");
Serial.println(<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.fahrenheit(), DEC);
lcd.setCursor(0, 0);
lcd.print("H%:");
lcd.print(<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.humidity, DEC);
lcd.print(" F:");
printDouble((<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.fahrenheit()),100);
lcd.setCursor(0, 1);
DPC= <span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.dewPoint();
Serial.print("Dew Point ( F): ");
Serial.println((DPC * 1.8) + 32);
Serial.println(DPC);
lcd.print("DP(F): ");
//lcd.print((1.8 * (<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.dewPoint(), DEC) + 32));
lcd.print((DPC * 1.8) + 32);
Serial.print("Dew Point ( C): ");
Serial.println(<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.dewPoint(), DEC);
Serial.print("Dew PointFast ( C): ");
Serial.println(<span class="domtooltips">DHT11<span class="domtooltips_tooltip" style="display: none">DHT11/22 is a digital Temperature & Humidity Sensor</span></span>.dewPointFast(), DEC);
delay(10000);
void printDouble( double val, unsigned int precision){
// prints val with number of decimal places determine by precision
// NOTE: precision is 1 followed by the number of zeros for the desired number of decimial places
// example: printDouble( 3.1415, 100); // prints 3.14 (two decimal places)
Serial.print (int(val)); //prints the int part
Serial.print("."); // print the decimal point
unsigned int frac;
if(val >= 0)
frac = (val - int(val)) * precision;
frac = (int(val)- val ) * precision;
Serial.println(frac,DEC) ;
lcd.print(val);
lcd.print(frac,DEC) ;
and i need some advice with calling the analog value to make the humidity comparator
Code:
if(valor.analogo<50) {
          digitalWrite(PIN3,HIGH);
          digitalWrite(PIN3,LOW);
          if(valor.analogo>70) {
             digitalWrite(PIN2,HIGH);
             digitalWrite(PIN2,LOW);
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
Does your include statement REALLY look like that?
Do not use the Copy For Forum option to post code.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Code:
Clearly that's nonsense as if valor.analogo is < 50 it can't also be > 70.
You need to read the value from the pin every time you are going to test it: use  analogRead() directly.
Logged
Pages: [1]   Go Up
Print
Jump to:
