« on: November 19, 2012, 10:11:46 am » |
where are things like DDRB DDRD PORTD PORTB defined
they are used like this (taken from others code) DDRD=0xFC; // direction variable for port D - make em all outputs except serial pins 0 & 1 DDRB=0xFF; // direction variable for port B - all outputs
PORTD = 0xFC; // all outputs except serial pins 0 & 1 PORTB = 0xFF; // turn on all pins of ports D & B
want to see what else I can access directly
eg is portE in 32u4 defined (Leonardo ) ?
Thanks in advance for any guidance
« Reply #1 on: November 19, 2012, 10:32:01 am » |
In the avr includes for your install of avr-gcc. For me on Ubuntu the relevant file is /usr/lib/avr/include/avr/iom328p.h
Left Coast, CA (USA)
Online
Measurement changes behavior
« Reply #2 on: November 19, 2012, 11:16:50 am » |
The AVR datasheet for the chip you are interested in is a good source of information for such information.
Lefty
« Reply #3 on: November 19, 2012, 05:52:32 pm » |
They are defined in the device header file, together with all other good stuff. A must read if you want to program a mcu.
France
Scientia potentia est.
« Reply #5 on: November 20, 2012, 12:29:08 am » |
How do I find out which Arduino pins are related to for example DDRA on my Arduino Mega 2560? I've looked the 2560 datasheet but could only find 2 occurences of "DDRA" and there isn't much infos (I know I will not find anything realted to Arduino in that datasheet but I'm trying to understand...).
« Last Edit: November 20, 2012, 12:34:18 am by guix »
Dallas
Online
Shannon Member
« Reply #6 on: November 20, 2012, 12:43:16 am » |
The I/O ports are labeled with a letter of the alphabet. For example, DDRA is the data direction register for I/O port A.
Physical pins are label with "P" then the port letter (e.g. "A") then a bit number from zero through seven. For example, physical pin 75 is labeled "PA3" which is I/O port A bit 3.
Typically, all the I/O ports have very similar characteristics and register sets. Instead of referring to the data direction register for each and every I/O port, the documentation usually uses "DDRx" to indicate "all data direction registers" (including DDRA).
Does that help?
France
« Reply #7 on: November 20, 2012, 12:52:36 am » |
Yes thanks, but how do I find the corresponding Arduino pin of PA3 ? In fact I would like to know, which "DDR" must be used for Arduino Mega's pins 22 to 53. Edit: Forget, I think I've found some useful infos in hardware\arduino\variants\mega\pins_arduino.h
« Last Edit: November 20, 2012, 12:54:10 am by guix »
Online
« Reply #8 on: November 20, 2012, 12:56:20 am » |
This worksheet may help you. If has the 'arduino pin number' in the first column that corresponds to the AVR port/bit of the chip, either for a mega168/328p or the mega1280/2560 chips. https://spreadsheets.google.com/pub?key=rtHw_R6eVL140KS9_G8GPkA&gid=0Lefty
France
« Reply #9 on: November 20, 2012, 01:03:14 am » |
Might be useful, thanks
« Reply #10 on: November 20, 2012, 02:08:55 am » |
google for "arduino mega pin mapping" or "arduino uno pin mapping"
both turn up good results.
« Reply #11 on: November 20, 2012, 04:43:20 am » |
try this tutorial.
From Idea To Invention
« Reply #12 on: November 20, 2012, 06:53:12 am » |
How do I find out which Arduino pins are related to for example DDRA on my Arduino Mega 2560? Google arduino pinout and see the images.
« Reply #13 on: November 20, 2012, 03:44:47 pm » |
Thanks for all the the replies very helpful.
Haven't had time to work out if that gives me access to PE2 on the 32U4 yet.
