Topic: Help needed for touch setup for 2.8 ILI9325C TFT display (MEGA 1280 U16)(SOLVED) (Read 4773 times) previous topic - next topic
rilas
hello everyone. i started a personal project to make a informational (at start) gadget for my moto
my initial setup included
1.Iteaduino UNO (http://imall.iteadstudio.com/development-platform/arduino/arduino-compatible-mainboard/im120905006.html)
2.ITDB02 Arduino Shield (http://imall.iteadstudio.com/development-platform/arduino/shields/im120417008.html)
3.ITDB02-2.8 (http://imall.iteadstudio.com/display/tft-lcm/im120419009.html)
so far all went good. I started coding/testing subsystems so i could
1.fully manipulate the tft screen ===> UTFT myGLCD(ITDB28,19,18,17,16);
2.use touch controls ==>  ITDB02_Touch myTouch(15,10,14,9,8);
3.read the SD card (over spi bus)
but then i saw that all my pins where in use from the tft screen and no space
for further development and sensors
so i decided to move to a bigger arduino
1.Arduino MEGA (ATMega 1280-16AU) (http://imall.iteadstudio.com/development-platform/arduino/arduino-compatible-mainboard/im120411002.html)
2.ITDB02 Arduino MEGA Shield   (http://imall.iteadstudio.com/development-platform/arduino/shields/im120417024.html)
and started testing code again to control each subsystem
1.fully manipulate the tft screen ===> UTFT myGLCD(ITDB28,38,39,40,41);
2............ITDB02_Touch  myTouch(6,5,4,3,2);
However i cannot get anywhere as far touch is concerned.
The ITDB02-2.8 seems fully operational (on iteaduino uno is ok) but i cannot get it
so far to work touch.
I believe i have followed the correct pin outs and the libraries support the ILI9325C chipset . so far i tested the touch with the following code
#include <UTFT.h>
#include <ITDB02_Touch.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
//UTFT myGLCD(ITDB28,19,18,17,16);               //UTFT(Model, RS, WR, CS, RST);                                  iteaduino
UTFT myGLCD(ITDB28,38,39,40,41);                  //UTFT(Model, RS, WR, CS, RST);                                   mega1280
//ITDB02_Touch myTouch(15,10,14,9,8);           // ITDB02_Touch(TCLK, TCS, TDIN, TDOUT, IRQ);            iteaduino
ITDB02_Touch  myTouch(6,5,4,3,2);                  // ITDB02_Touch(TCLK, TCS, TDIN, TDOUT, IRQ);             mega1280
 myGLCD.InitLCD();
 myGLCD.clrScr();
 myTouch.InitTouch(PORTRAIT);
 myTouch.setPrecision(PREC_MEDIUM);
 myGLCD.setFont(SmallFont);
 myGLCD.setColor(255, 0, 0);
 myGLCD.fillRect(0, 0, 319, 13);
 myGLCD.setColor(255, 255, 255);
 myGLCD.setBackColor(255, 0, 0);
 myGLCD.drawLine(0, 14, 319, 14);
 myGLCD.print("S.TISSEYRE - 2012", CENTER, 1);
 myGLCD.setBackColor(0, 0, 0);
 myGLCD.setColor(0, 255, 0);
 myGLCD.setFont(SevenSegNumFont);
 while (myTouch.dataAvailable() == true)
     int x,y;
     x = myTouch.getX();
     y = myTouch.getY();
     myGLCD.printNumI(x, CENTER, 50, 3, ':');
     myGLCD.printNumI(y, CENTER, 120, 3);
           myTouch.read();
MarkT
pinouts all seem OK from a quick check.
  while (myTouch.dataAvailable() == true)  /// ??
      int x,y;
      x = myTouch.getX();
      y = myTouch.getY();
            myTouch.read();
I'd never use this idiom, you are assuming there is a single value meaning true - in C this is not the case in
general, there is only a unique value for false.  Therefore I'd always write:
  while (myTouch.dataAvailable())
I don't know which version of the library you actually have, its discontinued, so couldn't find the source, but
the documentation claims dataAvailable() returns boolean, but its conceivable it once returned int, hence my
worry about using the value true.
Anyway back to the actual problem - my hunch is that you are calling getX() and getY() before calling read() - the documentation
is very unclear, but hints that you must call read() before getX() and getY().
rilas
thanks for the feedback.
i used the code from this thread   http://arduino.cc/forum/index.php?topic=119000.0
the library is this http://www.henningkarlsen.com/electronics/library.php?id=35 (as no other available i think but i'm open to try any other available)
the code above is working (switching the port mappings) to my first setup
myTouch.read(); i believe might be of little significance since its a loop
not get correct values first time, will get second
**Forgot to mention that on Mega 1280 "seems" that the first touch does something and then freeze.
while trying to write a troubleshooting code i think i get no data
put a      Serial.println(myTouch.getX(),myTouch.getY());        in my loop and get no data (#include <Serial.h> Serial.begin(9600);)
rilas
Finally i'm getting somewhere and it seems that its the end of my BIG problems
After a bit i came to realize that this 2.8 screen is a pain to work with
cause not much people got to work with it but managed to get started and probably finish my project.
First this screen is a 8bit bus and is missing the RTS pin so many can go wrong.
I could work with it with ITDB02 Mega shield (revision 2.1 on board) but touch
was out of the question while it was fully operational to Arduino with ITDB02 shield
1.I used this post http://zallison.com/2012/05/05/electronics-henning-karlsen/
   which converts the code to get an arduino ITDB02 shield to work on a MEGA.
   (there is a tiny error in the library that need correction at the end of HW_AVR.h
    _set_direction_registers(byte mode)  ==>   UTFT::_set_direction_registers(byte mode) )
   and initialized with UTFT myGLCD(ILI9325D_8,A5,A4,A3,A2);
   THIS GOT ME TO A FULLY WORKABLE SCREEN
2.Since ITDB02_Touch lib from  http://www.henningkarlsen.com/electronics
   worked for me went to get a fresh copy and for my surprise the new UTouch
   library is out so i took advantage of it to test. All went well  and got it to work
   with UTouch    myTouch(A1,8,A0,9,10);
First test is with UTouch_Button_test
// UTouch_ButtonTest (C)2010-2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a quick demo of how create and use buttons.
// This program requires the UTFT library.
// It is assumed that the display module is connected to an
// appropriate shield or that you know how to change the pin
// numbers in the setup.
#include <UTFT.h>
#include <UTouch.h>
// Uncomment the next two lines for the Arduino 2009/UNO
//UTFT        myGLCD(ITDB24D,19,18,17,16);   // Remember to change the model parameter to suit your display module!
//UTouch      myTouch(15,10,14,9,8);
// Uncomment the next two lines for the Arduino Mega
UTFT myGLCD(ILI9325D_8,A5,A4,A3,A2);   // Remember to change the model parameter to suit your display module!
int x, y;
char stCurrent[20]="";
int stCurrentLen=0;
char stLast[20]="";
**   Custom functions   **
void drawButtons()
// Draw the upper row of buttons
  for (x=0; x<5; x++)
    myGLCD.setColor(0, 0, 255);
    myGLCD.fillRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.drawRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.printNumI(x+1, 27+(x*60), 27);
// Draw the center row of buttons
  for (x=0; x<5; x++)
    myGLCD.fillRoundRect (10+(x*60), 70, 60+(x*60), 120);
    myGLCD.drawRoundRect (10+(x*60), 70, 60+(x*60), 120);
    if (x<4)
      myGLCD.printNumI(x+6, 27+(x*60), 87);
  myGLCD.print("0", 267, 87);
// Draw the lower row of buttons
  myGLCD.fillRoundRect (10, 130, 150, 180);
  myGLCD.drawRoundRect (10, 130, 150, 180);
  myGLCD.print("Clear", 40, 147);
  myGLCD.fillRoundRect (160, 130, 300, 180);
  myGLCD.drawRoundRect (160, 130, 300, 180);
  myGLCD.print("Enter", 190, 147);
  myGLCD.setBackColor (0, 0, 0);
void updateStr(int val)
  if (stCurrentLen<20)
    stCurrent[stCurrentLen]=val;
    stCurrent[stCurrentLen+1]='\0';
    stCurrentLen++;
    myGLCD.print(stCurrent, LEFT, 224);
    myGLCD.print("BUFFER FULL!", CENTER, 192);
    myGLCD.print("            ", CENTER, 192);
// Draw a red frame while a button is touched
void waitForIt(int x1, int y1, int x2, int y2)
  myGLCD.drawRoundRect (x1, y1, x2, y2);
    //while (myTouch.dataAvailable())     //commended out cause it had me stuck
    //myTouch.read();                            //and put a delay to button press
    delay(300);
**  Required functions  **
// Initial setup
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.InitTouch();
  myGLCD.setFont(BigFont);
  myGLCD.setBackColor(0, 0, 255);
  drawButtons();
  while (true)
    if (myTouch.dataAvailable())
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      if ((y>=10) && (y<=60))  // Upper row
        if ((x>=10) && (x<=60))  // Button: 1
          waitForIt(10, 10, 60, 60);
          updateStr('1');
        if ((x>=70) && (x<=120))  // Button: 2
          waitForIt(70, 10, 120, 60);
          updateStr('2');
        if ((x>=130) && (x<=180))  // Button: 3
          waitForIt(130, 10, 180, 60);
          updateStr('3');
        if ((x>=190) && (x<=240))  // Button: 4
          waitForIt(190, 10, 240, 60);
          updateStr('4');
        if ((x>=250) && (x<=300))  // Button: 5
          waitForIt(250, 10, 300, 60);
          updateStr('5');
      if ((y>=70) && (y<=120))  // Center row
        if ((x>=10) && (x<=60))  // Button: 6
          waitForIt(10, 70, 60, 120);
          updateStr('6');
        if ((x>=70) && (x<=120))  // Button: 7
          waitForIt(70, 70, 120, 120);
          updateStr('7');
        if ((x>=130) && (x<=180))  // Button: 8
          waitForIt(130, 70, 180, 120);
          updateStr('8');
        if ((x>=190) && (x<=240))  // Button: 9
          waitForIt(190, 70, 240, 120);
          updateStr('9');
        if ((x>=250) && (x<=300))  // Button: 0
          waitForIt(250, 70, 300, 120);
          updateStr('0');
      if ((y>=130) && (y<=180))  // Upper row
        if ((x>=10) && (x<=150))  // Button: Clear
          waitForIt(10, 130, 150, 180);
          stCurrent[0]='\0';
          stCurrentLen=0;
          myGLCD.setColor(0, 0, 0);
          myGLCD.fillRect(0, 224, 319, 239);
        if ((x>=160) && (x<=300))  // Button: Enter
          waitForIt(160, 130, 300, 180);
          if (stCurrentLen>0)
            for (x=0; x<stCurrentLen+1; x++)
              stLast
  • =stCurrent
                stCurrent[0]='\0';
                stCurrentLen=0;
                myGLCD.fillRect(0, 208, 319, 239);
                myGLCD.print(stLast, LEFT, 208);
                myGLCD.print("BUFFER EMPTY", CENTER, 192);
    the Utouch_Calibration not responds atm but i will try later
    Will post more code samples as i go
