Topic: bootloader for nano v3 (Read 3481 times) previous topic - next topic
muda
Can I somehow burn bootloader to my repaired nano using laptop and some cable via ICSP?
Seems like new atmega havent got  any bootloader on board.
CrossRoads
Yes, pretty easily.
In the IDE:
Tools: Select a Board - Uno will work well
Tools: Select your ICSP programmer (you do have a programmer, yes?)
Tools: Burn Bootloader
If you don't have a programmer, or a working Arduino, you are kinda out of luck.
Programmers can be found inexpensively, such as
http://www.nkcelectronics.com/pocket-avr-programmer.html
A programmer is a handy tool to have, everyone hobbyist should have one.  Or, keep a working Arduino around to run a programming sketch on to program other devices.
I've managed to accumulate 4 or 5 programmers, and use this one exclusively at the moment because it reliably programs the larger memory devices such as ATMega1284P:
http://www.mouser.com/ProductDetail/Atmel/ATAVRISP2/?qs=sGAEpiMZZMv256HIxPBQcA8%252bsNH3cLLR
muda
Thanks for answer . Unluckily I do not have a programmer or spare Arduino  :(
Can you explain how pocket programmer works  ? It comes with some cables or connector to connect to Arduino  ?
CrossRoads
The programmer connects to your PC at one end with a USB cable.
It connects at the other end to your Arduino board's ICSP 2x3 male header pins via a ribbon cable.
The pocket pirate I linked to includes a 10-pin to 6-pin ribbon cable.
muda
#4
Nov 15, 2012, 05:00 pm Last Edit: Nov 15, 2012, 05:10 pm by muda Reason: 1
Thanks again
Stupid question , but i will try : any chance I can use USB-TTL converter for that job ? Its somewhere in my boxes...
CrossRoads
Maybe:
http://www.geocities.jp/arduino_diecimila/bootloader/index_en.html
This uses the FTDI chip's
CTS, DSR, DCD, and RI pins - see the X3 connecter here
http://arduino.cc/en/uploads/Main/arduino-duemilanove-schematic.pdf
to drive the SCK, MOSI,  MISO, and Reset pins on the ICSO header.
If you can connect to them, this method does work.  I still have a Duemilanove set up pins added to make the connections above.  It takes a bit to set up all the files.
If you have Win7 or 8, there may be some extra fooling around to do as well to allow unsigned drivers, etc.  I saw yesterday that perhaps pressing F8 on bootup provides the option to turn that checking off.
muda
Win7 here .
Now lets start reading.
muda
#7
Nov 15, 2012, 05:38 pm Last Edit: Nov 15, 2012, 06:07 pm by muda Reason: 1
I dont know it is possible....
No X3 header on nano. USB chip so small , I cant imagine soldering wires directly to it.   :0
EDIT:
Or should I use my TTL converter instead ?  Then I need to find converter pinout...
Nope - converter has only Tx Rx on output  pins. Chip same size as on Arduino itself , so no soldering for me.
muda
Guys, where do I find bootloader file for nano  ?
I want to use with stand alone programmer.
muda
Solved.
There is one in bootloader folder. Just not marked as "P" , but works well.
