Author Topic: Standalone ATMega328P-Pu w/ Bootloader UNO not working!!  (Read 432 times)
Portugal
Hey!
I'm trying programming an Atmega328  w/ Uno Bootloader in a breadboard.
I'm using an Arduino UNO to program it
reset - pin1,
RX - pin2,
TX - pin3,
5V - pins 20 & 7,
GND - pins 22 & 8,
I tried the blink() sketch when uploading it gives me an error:
Binary sketch size: 1.084 bytes (of a 32.256 byte maximum)
What's wrong?
Massachusetts, USA
If it has the UNO bootloader it is expecting a 16 MHz crystal or ceramic resonator.
Portugal
Still the same output from the IDE when uploading, even using the 16MHz crystal.
i followed this tutorial:
http://revoltlab.com/projects/perfduino/
Massachusetts, USA
Did you try removing the 328P from the Arduino UNO and inserting the chip you want to program? If the UNO stops uploading that will tell you that something is wrong with that bootloader.
Try to follow this tutorial:
http://pdp11.byethost12.com/AVR/ArduinoAsProgrammer.htm
It allows you to program any target AVR directely with any code you want, ex. "blink a led".
You do not really need to write a bootloader on the chip, first.
« Last Edit: November 19, 2012, 10:16:01 pm by simplex » Logged
Portugal
Yhep!
All seems to work just fine when loading the code with the atmega on UNO.
Does Arduino IDE needs specific preferences for this procedure?
BTW...
I saw a few days ago, an hardware "library" called "Atmega328 breadboard" but when I try to configure pin 13 (ledpin) as an output it gives me a library error...
« Last Edit: November 19, 2012, 08:45:58 pm by lookslikeruck » Logged
Massachusetts, USA
So the problem must be in your breadboard or in your USB-to-Serial conversion.
