Topic: Need an air flow generating unit for automatic wind instrument (Read 6109 times) previous topic - next topic
Liepa
I'm making a project that incorporates several DIY PVC recorders that are going to be played by Arduino and I need a system that generates air flow to play them. I have some spare fans from my old pc laying around but they are a bit too wide and not powerful enough (unless I make a complicated tubing system to aggregate the wide airflow into narrower and stronger one). I was thinking of hacking a mini vacuum cleaner (http://www.ebay.co.uk/itm/300817216993) cause they tend to have more condensed and stronger air flow (I'd have to invert the direction though). The only thing is that the mini vacuum cleaner might be a bit too loud. I don't mind a certain amount of noise from the fan but I have no idea how loud the mini vacuum cleaners are. I also found this tutorial on how to build a blade-less air fan (http://youtu.be/4q4PZpl59GU) but I have no idea if the air pressure created by it would not just go back through the massive hole in the middle. My question is - is there any other way to generate air flow? Or should I stick to hacking the mini vacuum cleaner? Also, I want to be able to play several recorders with one fan if possible - does anyone have any suggestions on how to arrange them so the air flow from the fan would be equal strong to all of them?
Thanks.
robtillaart
what's the pressure you need? the wind speed ? volume/sec?
small compressor (air brush)
Rob Tillaart
Liepa
#2
Nov 19, 2012, 11:10 pm Last Edit: Nov 19, 2012, 11:12 pm by Liepa Reason: 1
I am sorry I didn't provide more details but I have no way to measure the air pressure needed for a PVC recorder. It is not a lot - way less than for a flute or saxophone or other proper wind instrument. I am just looking into ways/components to generate air pressure so I can experiment and find a proper solution. I think an air brush might work good - I haven't thought of that. Thanks
billroy
Perhaps a bellows, like an accordion.  You can make them from paper.  Or maybe you can find an old bagpipe.  That would be stylish.
-br
http://bitlash.net
Jimmy60
An air brush won't work, you want the pressurized air supply that powers it.
Sounds like you need what we call an "air pig" or a compressed air tank. More importantly you need a pressure regulator to vary and maintain pressure. Not to be confused with a pressure gauge which only reads the pressure, a regulator regulates the pressure. You may find this stuff at a good hardware store.
PeterH
How long do you need to operate it for? I'm no musician but I've seen them played and have the impression they need quite a bit of pressure - probably several PSI - which would be hard to generate from a fan. I suspect you could operate it from a balloon for several seconds if you wanted to try that to prove the principle - then your problem would be how to get a pump/fan to generate similar pressure at the required flow rate.
Liepa
Best case scenario I'd need them to play indefinitely until I turn them off myself. The recorders I have made are of a small scale and require less pressure than regular wind instruments. I am tempted to try out the mini air compressor like this
www.google.co.uk/products/catalog?hl=en&client=firefox-a&rls=org.mozilla:en-US:official&channel=fflb&q=mini+air+compressor&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.&bpcl=38625945&biw=1846&bih=987&um=1&ie=UTF-8&cid=5286243728415743297&sa=X&ei=YrCqULPdO8a90QWZh4CYAQ&ved=0CH0Q8wIwAw
it produces up to 250 psi so it is strong enough. It might be too loud and I am not sure if I can find a good way to control the pressure of air that it produces.
billroy
Here is a thread that suggests 0-10 psi is the normal human production playing the flute.  It also suggests a small compressor for a similar project:
http://groups.yahoo.com/group/nativeflutewoodworking/message/35254
-br
Jimmy60
That is capable of inflating something to 250psi but the air pressure coming out of it is much smaller. It might actually be not to bad for your needs. Your best bet is an air tank, with a regulator on it inflated by a compressor. A regulator is that good way to control the pressure as well as experiment with different pressures. The idea behind a regulator is that you could have tank with 250 psi in it and the regulator would limit it's output to say 10 psi. It will also deliver 10 psi until the tank's pressure dropped below that. I'd also recommend a pump that plugs into mains, the one you linked to really needs a car battery.
Liepa
Thanks everyone for your help, I've done quite valuable googling based on your suggestions and found several other candidate components for my project:
- aquarium air pumps (the ones that produce bubbles) are quiet and cheap but I still have to look out if they are powerful enough
- micro air pumps like this (https://www.youtube.com/watch?v=ux5lRQt77wU) and the ones that are used in medical equipment (http://www.pneumaticschina.com/mini-pumps/micro-diaphragm-pump/dl7bldc-micro-diaphragm-gas-pump.html). One major bonus is that they are quiet.
Did anyone have any experience using those in projects?
the major problem with those mini air compressors for car tires is that they are extremely loud - as I mentioned before I don't mind some noise but not so much that you can't hear the recorders themselves. From the videos on youtube these air compressors seem very very loud: http://youtu.be/1xq478qeV4Q, http://youtu.be/x9lZbmrBpIY
Jimmy60
LOL
I just came back to mention that those car tire pumps are really loud. Most air compressors are but a tank of compressed air isn't.
PeterH
Yes, car tyre inflators are always very loud, and also tend to be very low flow rate (and the higher pressure ones are even lower).
I suspect you need something in the region of a couple of liters per minute at a few psi, but it would really be a good idea to find out what pressure and flow rate you actually need. There are plenty of ways to do this, even starting with how hard you have to blow and how long a lungful of air lasts. Come on, you've got these things in front of you.
Chagrin
2.3 PSI (120 mm Hg) is normal blood pressure and about the best that a fit person can blow in short bursts. 3.5 PSI (180 mm Hg) is dying. The 6 PSI stated by your thread sounds remarkably high.
To the OP's question, the best suggestion I can think of for an inexpensive, quiet pump would be the compressor from a refrigerator. Google will turn up a few results on how woodworkers convert them for use as vacuum presses.
Liepa
Thanks for the info - that's very useful. The fridge compressor might work but is a bit big. For now I have ordered one of these http://www.ebay.co.uk/itm/RC-Submarine-MICRO-AIR-PUMP-DC-3v-7-2v-/280999690355?pt=US_Character_Radio_Control_Toys&hash=item416ce30073. If it doesn't work well for me I'll definitely try the fridge compressor option.
jabbado
That submarine pump creates a fair bit of pressure but is lacking in cfm like the small car compressors. I don't think a fridge compressor will give you enough flow either.
Wouldn't a decent sized centrifugal fan work for this? I thought recorders don't have all that much air resistance. In fact wikipedia mentions pipe organs use pressures in the order of 0.1 psi which equates to roughly 2.75 inch-aqua. I'm pretty sure even small centrifugal fans that were used in computers years ago can create static pressures higher than that.
