Loading...
Pages: [1]   Go Down
Author Topic: Modbus 1/7/N/1  (Read 274 times)
Offline Offline
Newbie
View Profile
Hi, i'm trying to communicate with a MODBUS slave device.  The data sheet shows the protocol to be:
  Modbus ASCII
  RS-485
  9600 bps baud rate
  1 start bit, 7 data bits, no parity, 2 stop bits
  LRC (Longitudinal Redundancy Check)
Presumably I will need a RS485 breakout to convert the Arduino's UART serial to RS-485?
What about the frame format?  I think the Arduino is set to 8N1, so I need to somehow change that to 1 start bit, 7N1.
How do I go about changing this?  Can it even be done?
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
You can simulate 7N2 with 8N1 by always setting the most significant bit to 1 for each byte sent.
Logged
Offline Offline
Newbie
View Profile
Thanks Louis, how do I set the MSB to 0?  Is that really all I need to do?
Logged
Offline Offline
Newbie
View Profile
For 25 LEDs you only need 4 shift registers.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Where did 25 LEDs get mentioned? Or shift registers?
Logged
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
That was another thread smiley
Quote
He said "setting the most significant bit to 1" BTW.
For every byte you send OR it with 0x80. Eg
Code:
send_modbus_byte (my_byte | 0x80);
Quote
Should be.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
United States
Offline Offline
Newbie
View Profile
Did you find a library you liked for modbus communication yet?
Logged
Pages: [1]   Go Up
Print
Jump to:
