Topic: Running DC Motor with H-Bridge Circuit (Read 2510 times) previous topic - next topic
rlgryzyn
Hi all,
I'm trying to use the following circuit diagram (picture attached) to run a 12v DC motor in alternating directions, controlled by an Arduino board. The circuit works well when either side of the transistor pair is attached to the motor independently, however, when the circuit is fully wired so that both transistor pairs are attached to the motor, it doesn't run and at least one transistor begins to put off a none-too-pleasant odor. I've looked over the diagram and my wiring several many times at this point and I cannot seem to figure out why this would be happening.
Does anyone have any idea where the problem may lie?
One note about the diagram: I have followed it faithfully except for the device between the H-bridge and the Arduino board. I have omitted this element and am sending a 5v signal directly from the Arduino board via digitalWrite(). I am also not using the capacitor attached to the power source the diagram calls for. Here is the full testing code I'm using, which should cause the motor to run in one direction:
const int transPin2 = 2;
const int transPin4 = 4;
  pinMode(transPin2, OUTPUT);
  pinMode(transPin4, OUTPUT);
  digitalWrite(transPin2, HIGH);
  digitalWrite(transPin4, LOW);
Thanks for any tips or help identifying what I'm overlooking.
johnwasser
It is my impression that a HIGH voltage in the base of a P-channel MOSFET will turn it OFF.  That would mean that turning Q4 on would turn Q1 off.  Similarly turning Q3 on would turn Q2 off.  If both outputs are LOW the two upper transistors are ON and both lower transistors are OFF.  Similarly, if both outputs are HIGH the two lower transistors are ON and both upper transistors are OFF.
The problem comes when one output is HIGH and the other is LOW.  This will cause a direct short through Q1/Q3 or Q2/Q4.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
zoomkat
Simple internet h-bridge diagrams don't seem to actually work in real life. I don't know how the control chip works, but sounds like control lines to the transistors may have some floating voltage causing the short circuit condition. The PNP transistors may be the ones getting overheated (that has been my experience in my brief DIY h-bridge tinkering) and subsiquently damaged.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
dc42
#3
Nov 20, 2012, 11:18 am Last Edit: Nov 20, 2012, 11:20 am by dc42 Reason: 1
For that to work, you need to connect the gate of each P-channel mosfet to the gate of the N-channel mosfet on the same side of the bridge, not to the one on the opposite side as you have now. So each output of the driver chip will drive one of the mosfet pairs.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
