Loading...
Pages: [1]   Go Down
Author Topic: Draw disconnected nets in Eagle?  (Read 1251 times)
Southern California
Offline Offline
Sr. Member
I like blinky lights
View Profile
WWW
Is there any way in Eagle to disconnect nets like the attached picture, to reduce clutter on more complicated designs?
Logged
http://en.wiktionary.org/wiki/magagna <-- My last name.  Pretty apt.
USA, FL
Offline Offline
God Member
A life? Where can I download one of those?
View Profile
Yes, make a short net coming off the pin.  Name it something meaningful to that pin.  Do the same on another pin that you want a net connected to.  Name that pin/net the same as the first one you did.  It will ask you if you want to connect "N$x" to "yourName."  Hit ok.  now you will see on the board view that there is a connection between the pins and you can route it.
Don't forget to add a label to the net so you what what it is!
Logged
//LiNK
0
Offline Offline
Faraday Member
View Profile
codlink's method is what I use.
If you want to take it one step further and get the flag style labels, click info ("i" icon), then select the label in question.  check the "Xref" box, and the label transforms from floating text to text in a box.
-j
Logged
Southern California
Offline Offline
Sr. Member
View Profile
WWW
That's exactly what I wanted. Thanks to you both.
Logged
Pages: [1]   Go Up
Print
Jump to:
