Offline
Newbie
« on: November 19, 2012, 08:36:15 pm » |
Halo friend. I need your help.
I have arduino UNO, Accelerometer adxl335 and GPS EM411 I want to build a third communication device with the following scenario:
When the Arduino is turned on, the GPS reading. if the GPS status = valid, then the GPS will send GPRMC position to the computer. Once the position is received, then sends accelerometer vibration conditions x, y, z.
I've tried from a few examples of the forum but when executed, the status of the GPS readings are still messed up.
I beg for help. thank you
This is my code:
////////////////////////////////////////////////////////////////// //Sensor Acceleroemter ADXL335 //////////////////////////////////////////////////////////////////
#include <SoftwareSerial.h> #include <nmea.h> SoftwareSerial GPS = SoftwareSerial(11,12);
//read pin analog accelerometer const int xPin = A0; const int yPin = A1; const int zPin = A2;
//read parameter gps byte SWval; char dataformat [7] = "$GPRMC"; char messageline[200] = ""; int i = 0; byte rx = 11; byte tx = 12; #define bit9600Delay 84 #define halfBit9600Delay 42 #define bit4800Delay 188 #define halfBit4800Delay 94
//The minimum and maximum values //take when the accelerometer standing still int minVal = 226; int maxVal = 286;
//hold the caculated values double x; double y; double z;
void setup(){ Serial.begin(9600); //print posisi GPS char2string(); //for (int i=0;i<201;i++){ // Initialize a buffer for received data // messageline=' '; //} Serial.print(messageline); Serial.println(""); delay(200); }
void loop(){ //read the analog values from the accelerometer int xRead = analogRead(xPin); int yRead = analogRead(yPin); int zRead = analogRead(zPin);
//convert read values to degrees -90 to 90 - Needed for atan2 int xAng = map(xRead, minVal, maxVal, -90, 90); int yAng = map(yRead, minVal, maxVal, -90, 90); int zAng = map(zRead, minVal, maxVal, -90, 90);
//Caculate 360deg values like so: atan2(-yAng, -zAng) //atan2 outputs the value of -π to π (radians) //We are then converting the radians to degrees x = RAD_TO_DEG * (atan2(-yAng, -zAng) + PI); y = RAD_TO_DEG * (atan2(-xAng, -zAng) + PI); z = RAD_TO_DEG * (atan2(-yAng, -xAng) + PI); //Output the caculations Serial.print("x: "); Serial.print(x); Serial.print(" | y: "); Serial.print(y); Serial.print(" | z: "); Serial.println(z); // if(x= delay(100);//just here to slow down the serial output - Easier to read
//Led konfirm int ledPinX = 7; //whatever PWM digital pin you want int ledPinY = 8; //whatever PWM digital pin you want int ledPinZ = 9; //whatever PWM digital pin you want pinMode(ledPinX, OUTPUT); pinMode(ledPinY, OUTPUT); pinMode(ledPinZ, OUTPUT); int LEDx = map(x, 0, 180, 0, 1023); int LEDy = map(y, 0, 180, 0, 1023); int LEDz = map(z, 0, 180, 0, 1023); analogWrite(ledPinX, LEDx); analogWrite(ledPinY, LEDy); analogWrite(ledPinZ, LEDz); }
//fungsi SWread int SWread(){ byte val = 0; while (digitalRead(rx)); //wait for start bit if (digitalRead(rx) == LOW) { delayMicroseconds(halfBit4800Delay); for (int offset = 0; offset < 8; offset++) { delayMicroseconds(bit4800Delay); val |= digitalRead(rx) << offset; } delayMicroseconds(bit4800Delay); return val; } }
//fungsi char2string void char2string(){ i=0; messageline[0] = SWread(); while (messageline != 13) //carriage return or max size { i++; messageline = SWread(); } Serial.write(SWread()); }
and result is :
I$=²44Ð,¹æ:3
æÆ99q93Í3y635q6:Å006¹31ŹÆ.ÅqÅ03qÆÇ89yÖ9ÅN,æÙæ6ÍqÆÆ80&ÙÆA
x: 16.65 | y: 19.32 | z: 40.46 x: 16.81 | y: 18.97 | z: 41.31 x: 17.42 | y: 17.93 | z: 44.12 x: 18.10 | y: 16.09 | z: 48.58 x: 19.84 | y: 27.27 | z: 34.99 x: 18.25 | y: 34.66 | z: 25.50 x: 20.56 | y: 33.94 | z: 29.12 x: 20.25 | y: 31.45 | z: 31.10 x: 22.62 | y: 39.09 | z: 27.15 x: 21.80 | y: 38.66 | z: 26.57 x: 17.90 | y: 27.98 | z: 31.29 x: 18.28 | y: 20.15 | z: 41.99 x: 19.98 | y: 38.50 | z: 24.57 x: 16.59 | y: 35.48 | z: 22.68 x: 14.97 | y: 31.13 | z: 23.88 x: 13.15 | y: 25.92 | z: 25.68 x: 11.62 | y: 31.67 | z: 18.43 x: 9.46 | y: 31.04 | z: 15.48 x: 12.37 | y: 32.28 | z: 19.15 x: 7.93 | y: 34.85 | z: 11.31 x: 3.53 | y: 39.17 | z: 4.33 x: 6.12 | y: 37.30 | z: 8.00 x: 358.21 | y: 22.11 | z: 355.60 x: 352.07 | y: 30.75 | z: 346.83 x: 1.40 | y: 30.34 | z: 2.39 x: 358.78 | y: 33.ÿ
