Topic: What is thickest gauge wire that can be inserted into Arduino headers? (Read 7058 times) previous topic - next topic
encryptor
What is thickest gauge wire that can be inserted into Arduino headers OR breadboard?  The standard I see is 22 gauge, however if I'm going to buy more wire I want the most amp for my buck!  Can 22 gauge wire support up to 1 amp?  :smiley-mr-green:
peace*&^
Osgeld
depends on voltage and how long you run it (heck "they" say you can run an amp though 30 gauge) ... though none of the parts on the arduino can sustain an amp for long
retrolefty
#2
Nov 20, 2012, 05:54 am Last Edit: Nov 20, 2012, 05:56 am by retrolefty Reason: 1
Only the wire insulation is a factor in it's maximum voltage rating, not it's current rating, which is only dependent on its gauge thickness regardless of the voltage used in a circuit.
Here is a current Vs gauge chart that might help the OP:
http://www.cablesandconnectors.com/wiregauge.html
The following chart is a guideline of ampacity or copper wire current carrying capacity following the Handbook of Electronic Tables and Formulas for American Wire Gauge. As you might guess, the rated ampacities are just a rule of thumb. In careful engineering the voltage drop, insulation temperature limit, thickness, thermal conductivity, and air convection and temperature should all be taken into account. The Maximum Amps for Power Transmission uses the 700 circular mils per amp rule, which is very very conservative. The Maximum Amps for Chassis Wiring is also a conservative rating, but is meant for wiring in air, and not in a bundle. For short lengths of wire, such as is used in battery packs you should trade off the resistance and load with size, weight, and flexibility. NOTE: For installations that need to conform to the National Electrical Code, you must use their guidelines. Contact your local electrician to find out what is legal!
Lefty
fungus
You can, but that doesn't make it a good idea.
For starters you'll have quite a voltage drop along the wire.
Grumpy_Mike
There is not much point in getting thick wire as you should only draw 40mA or less from an arduino pin. Anything you can plug in will take that.
MichaelMeissner
I bought some hookup wire initially from Radio Shack that I had trouble fitting in some breadboards (as I recall, the female pins in the Arduino itself were ok with the larger wire).  Eventually after getting 22 gauge wire, I recycled it, so I don't remember the exact size, but I believe it was 20 gauge.
