Loading...
Pages: [1]   Go Down
Author Topic: Silencing audiable PWM signals  (Read 382 times)
Offline Offline
Jr. Member
View Profile
I have this hefty 12 volt fan that has its speed regulated via PWM. It buzzes very loudly when in use and I wish to silence it.
A simple 25v 10uF capacitor on the fan's input lessons the sound slightly. An increase in capacitance lessons the sound more, but limits the range in speed control for the fan. (i.e. 50% duity cycle and up shows no change in the speed for the fan.)
The PWM frequency is 76Hz.
Finally, some brief specs on the fan are:
- Voltage range = 7.0 - 13.8
- Current = 710mA
- Input = 8.52w
Changing the supplied PWM frequency is not one of my options at this time.
« Last Edit: November 20, 2012, 01:31:11 am by physics-dude » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Then you will most likely just have to learn to live with the sound. Changing PWM frequency is probably the solution required, unless you wish to convert to pure analog voltage control via a heatsinked power transistor(s) operating in it's linear range.
Lefty
Logged
Offline Offline
Edison Member
View Profile
Lower the pwm frequency.
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
 smiley-roll-blue
Logged
Don't React -- Read!
Canada
Offline Offline
Sr. Member
Sometimes teaching, always learning,
View Profile
Your post doesn't say if your source of the PWM is an arduino, or even if an arduino is involved here.
If you have a spare arduino lying around (or attiny), you could feed the source of the 76Hz PWM through a low pass filter into an analog input. Set an output PWM proportional to the input at a frequency of your choice.
Problem solved with minimal parts.
Logged
Offline Offline
Jr. Member
View Profile
The source of the PWM is the Melzi electronics on my new RepRap. The whole system is based off the Arduino Leonardo and utilizes the ATMEGA644P.
Edit: I got everything working just fine now thanks in part to users on the RepRap forums.
I forgot to mention here that I had a 12v regulator between the 19v Melzi electronics and fan. The first couple I was using weren’t quite in spec, but these new ones,  NJM7812FA, work like a charm. With that, the only other thing I included was a 35v 100uF cap on the fan's input.
« Last Edit: November 22, 2012, 03:47:02 am by physics-dude » Logged
Pages: [1]   Go Up
Print
Jump to:
