Loading...
Pages: [1]   Go Down
Author Topic: Basic Principal Injecting Voltage?  (Read 250 times)
Offline Offline
God Member
View Profile
I've always wondered how they added a frequency to carry data or inject a 48v power line to power an arduino via ethernet.
But, what's the rules, i can inject as many AC frequencies providing it's different into an existing being used AC line?
for example, if i decided to power my house from a 22vac low voltage line around the home, what could you "inject" and how? diodes? timing?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Isn't the "power" in Power-over-Ethernet DC?
Logged
Offline Offline
God Member
View Profile
Can i inject an AC signal into an existing AC line? eg a data line?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
For injecting an RF carrier into mains wiring I'm not sure - there are a lot of different standards: http://en.wikipedia.org/wiki/Power_line_communication.
For power-over-ethernet the data signal is already balanced and transformer-coupled so you only have to replace certain centre-tap ground-connections with the power rail I believe - although for ether with spare pairs (100Mbit) power can also simply be wired through the spare pairs.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Yes. The X-10 standard has been one method used for several decades for sending and receiving signalling information over a typical household AC power wiring to allow remote control of lighting and other consumer devices. Here is a pretty good write up on the method the standard uses and even gives example of interface circuitry that can be used. http://www.x10pro.com/pro/pdf/technote.pdf
Lefty
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
There's also an X 10 Library in the playground and the X 10 modems can be found on Ebay. I bought 3 for about $15.00 Ea.. In an hour, 2 for a project I'm working on and one spare. There are 2 types TW523/PSC06 duplex or TW513/PSC05 simplex. Lefty pointed put that there is an active forum that 'looks' OK with more than a few Arduino users... Too.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Pages: [1]   Go Up
Print
Jump to:
