Topic: Schmitt Trigger. (Read 3485 times) previous topic - next topic
cjdelphi
Other than using a 555 as a schmitt trigger...
I bought 5 off these off of ebay, I was looking for a simple case of, feed the analogue voltage signal in, 1v, 2v, 4v, 5v, etc, and simply have two states, high or low, so in my head I had this
Voltage DC In > Voltage DC 5v High, Voltage 0v LOW.
So the best i could find on ebay was the 74HC14 7414 IC CMOS 14 PIN HEX SCHMITT TRIGGER INVERTER.
Nor is the voltage threshold of when High becomes high and Low becomes Low (what voltage? is that depending on Voltage in?) - anyway I got 5 of these i'm expecting any moment
could i simply feed it into 1 logic gate, get the inverted signal, and feed that into a 2nd gate, giving me a nice Schmitt Trigger ?
Grumpy_Mike
I am not sure what you are trying to do but there is no advantage in pitting two gates in seriese. The threshold is arround 2.4V from memory with a 0.5V or so hysteresis.
If you want a variable threshold then use a comparator like an LM399.
cjdelphi
you answered half my question, inbuilt set voltages (cool, perfect thanks)
I want to feed a voltage in > 1v = low 5v = high.
but this is a Hex Inverted, if i feed in 1v, i'll get a High, i want a Low, so i'm asking would it be perfectly legit to simply feed it back in and get a low from 1V and a high from 5v
1v in > out (high as it's inverted) > back in ....in out > LOW
using 2 logic gates out of the 4 to get a schmitt trigger LOW/HIGH without an inverted signal.
Grumpy_Mike
Yes you can invert the signal like this, but if it is feeding into an arduino there is no point.
cjdelphi
No arduino, i bought a selection of logic chips, just to get a better understanding of logic gates and well computers in general, building 1 bit storage registers using flip flops, how to convert an analouge into a digital signal etc etc... it's just fun right now :)
Grumpy_Mike
OK, yes just wire them up any way you want input to output.
cjdelphi
I have several flip flops (d type), and soon some and/or/nand (only one that are schmitt triggered) gates and I hope to create myself 8 bits of memory out of pure logic gates and use Arduino to retrieve / store :)
i'm a long way but you have to start somewhere lol
Grumpy_Mike
Good luck.
Have you seen the 74LS81 ?
cjdelphi
74LS81
can't find any info on it, got a datasheet?
runaway_pancake
... I hope to create myself 8 bits of memory out of pure logic gates ...
From 2-input NORs or NANDs you can make RS Latches (a/k/a SR Latches).
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
cjdelphi
cool, i'm just waiting on the the logic chips to arrive to have to have some fun :)
dhenry
You may think about a 2-input chip like hc132: they are flexible enough for you to configure other logic easily from.
Grumpy_Mike
74LS81
No it's a bit old, try the 74LS89.
