Topic: 2 codes in 1 software (Read 2363 times) previous topic - next topic
florin
Hi!
I have made 2 different softwares in Arduino IDE. I want to make a software like: first code
        delay(500000)
        second code
How i can call that 2 softwares in one?
PaulS
You've shown 0 of them.
        delay(500000)
        second code
Feel free.
Without seeing your code? No clue.
If one sketch is for reading RFID cards, and one is for watering plants, why do you want to combine them? Why the 6 minute and 20 second delay? Seems like a strange interval.
What happens when the second code finishes? The first will be run again, immediately. Is that OK?
florin
The full software will run non-stop.Software will run the first code(wich contain functions), than wait 5 minutes , than run the second code. When the second code is end,  repeat non- stop the full code.
fungus
So...what's the problem? What prevents you from doing this?
  code1();
  delay(500000)
  code2();
florin
I need to run first code for a time interval, than code 2 for another time interval.
AWOL
Have a look at the blink without delay example, without delay.
florin
I have made a circuit for the code below:
void loop(){
time=millis();
while(millis()-time<10000)
    first code
time=millis();
The circuit run the first code for ten seconds, than the second code for 10 second, than first code for ten 10 seconde and than STOP. Why?
billroy
Can't say without seeing all your code (post it all, please), but at a guess you may have declared time as an int instead of an unsigned long.  At least that is what usually causes weird behavior during the first 30 seconds after startup.
-br
http://bitlash.net
