Topic: Float to array? (Read 977 times) previous topic - next topic
0miker0
I have a few seven segment leds and I want the temperature ic float displayed. The code is set up so an integer is assigned to each digit.
(working test code)
int a=1;
int b=2;
int c=3;
write_digits(a,b,c);
Is there an easy way to have a float to array? Then my temperature ic could do something like:
float temperature = getTemp();
somehow put the float into an array
write_digits(temp[0],temp[1],temp[2],temp[3]);
Arrch
#1
Nov 20, 2012, 09:30 pm Last Edit: Nov 20, 2012, 09:40 pm by Arrch Reason: 1
dtostrf()
Although, since you know the precision you want, you could just multiply it by 10^n, where n is how many digits you want, assign it to an int, and send it through atoi().
dhenry
Quote
Typically done with divisions:
Code: [Select]
 c=temperature % 10;  temperature / = 10;
 b=temperature % 10;  temperature / = 10;
 a=temperature % 10;
For that to be fast and accurate, you want temperature to be an integer.
So here is the irony of your proposal: you want to convert an integer into float, only to have to convert it back to integer so you can do what you are trying to do.
robtillaart
dhenry is 100% right, integer math is much faster. however the last - % -modulo - is not needed ;)
Code: [Select]
int t = (int)temperature;
c= t % 10;  t /= 10;
b=t % 10;   t /= 10;
a=t;  // assume temp = 0..999
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
0miker0
It works! Thanks to all for the help. I'm trying to figure it now since I stick to hardware design and rarely write code. I have no idea what the line t /= 10; is yet but i'll figure it out. I think I have the rest of it in my head.
Mike
Arrch
Mike
It's shorthand for writing out the full assignment statement:
t = t / 10.
In English, it says take the variable t, divide it by 10 and store it back in t.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
