Author Topic: Float to array?  (Read 183 times)
Nova Scotia
I have a few seven segment leds and I want the temperature ic float displayed. The code is set up so an integer is assigned to each digit.
(working test code)
 int a=1;
 int b=2;
 int c=3;
write_digits(a,b,c);
Is there an easy way to have a float to array? Then my temperature ic could do something like:
float temperature = getTemp();
somehow put the float into an array
write_digits(temp[0],temp[1],temp[2],temp[3]);
California
dtostrf()
Although, since you know the precision you want, you could just multiply it by 10^n, where n is how many digits you want, assign it to an int, and send it through atoi().
« Last Edit: November 20, 2012, 03:40:16 pm by Arrch » Logged
Typically done with divisions:
 c=temperature % 10;  temperature / = 10;
  b=temperature % 10;  temperature / = 10;
  a=temperature % 10;
For that to be fast and accurate, you want temperature to be an integer.
So here is the irony of your proposal: you want to convert an integer into float, only to have to convert it back to integer so you can do what you are trying to do.
Netherlands
dhenry is 100% right, integer math is much faster. however the last - % -modulo - is not needed smiley-wink
int t = (int)temperature;
c= t % 10;  t /= 10;
b=t % 10;   t /= 10;
a=t;  // assume temp = 0..999
Rob Tillaart
Nova Scotia
It works! Thanks to all for the help. I'm trying to figure it now since I stick to hardware design and rarely write code. I have no idea what the line t /= 10; is yet but i'll figure it out. I think I have the rest of it in my head.
Mike
California
Mike
It's shorthand for writing out the full assignment statement:
t = t / 10.
In English, it says take the variable t, divide it by 10 and store it back in t.
