Loading...
Pages: [1]   Go Down
Author Topic: dht11 with comparators  (Read 296 times)
Offline Offline
Newbie
View Profile
Hi, i have this code working with dht11 + lcd but i need to introduce a comparators something like if humidity is lower than 40% then turn a led and with temperature the same thing like if higher than 23 C then turn another led
Code working with no comparators DHT11 + LCD
#define dht_dpin 14
#define LIGHT_SENSOR_PIN 1
#include <LiquidCrystal.h>
LiquidCrystal lcd(0, 1, 2, 3, 4, 5);
byte bGlobalErr;
byte dht_dat[4];
int light_intensity = 0;
unsigned int flip = 0;
void setup(){
        pinMode(13, OUTPUT);
        lcd.begin(16, 2);
        lcd.print("Heeeeeello!");
        InitDHT();
        delay(300);
        delay(700);
void loop(){
        if ( flip & 1 )
                digitalWrite(13, HIGH);
                digitalWrite(13, LOW);
        flip++;
        light_intensity=analogRead(LIGHT_SENSOR_PIN);
        ReadDHT();
        switch (bGlobalErr) {
        case 0:
                lcd.setCursor(0, 0);
                lcd.print("temp =       ");
                lcd.setCursor(7, 0);
                lcd.print( dht_dat[2], DEC);
                lcd.setCursor(0, 1);
                if ((flip % 15) > 7 )
                        lcd.print("humidity = ");
                        lcd.setCursor(11, 1);
                        lcd.print( dht_dat[0], DEC);
                        lcd.print("Light =         ");
                        lcd.setCursor(8, 1);
                        lcd.print( light_intensity, DEC);
        case 1:
        case 2:
        case 3:
        default:
        delay(800);
void InitDHT(){
        pinMode(dht_dpin,OUTPUT);
        digitalWrite(dht_dpin,HIGH);
void ReadDHT(){
        bGlobalErr=0;
        byte dht_in;
        byte i;
        digitalWrite(dht_dpin,LOW);
        delay(18);
        delayMicroseconds(600);
        delayMicroseconds(40);
        pinMode(dht_dpin,INPUT);
        dht_in=digitalRead(dht_dpin);
        if(dht_in) {
                bGlobalErr=1;
                return;
        delayMicroseconds(80);
        if(!dht_in) {
                bGlobalErr=2;
                return;
        delayMicroseconds(70);
        for (i=0; i<5; i++)
                dht_dat = read_dht_dat();
        byte dht_check_sum =
                dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];
        if(dht_dat[4]!= dht_check_sum)
        {bGlobalErr=3; }
byte read_dht_dat(){
        byte i = 0;
        byte result=0;
        for(i=0; i< 8; i++) {
                while(digitalRead(dht_dpin)==LOW) ;
                delayMicroseconds(30);
                if (digitalRead(dht_dpin)==HIGH)
                        result |=(1<<(7-i));
                while (digitalRead(dht_dpin)==HIGH) ;
        return result;
Logged
Offline Offline
Edison Member
View Profile
Quote
That's easy:
Code:
  read_dht11();
  if dht11.humidity < 40% turn on a led;
  else turn off the led;
  if hdt11.temperature > 23 turn on another led;
Code:
        for (i=0; i<5; i++)
Nicely done.
Logged
Offline Offline
Newbie
View Profile
thank you dhenry for your reply, in fact i did that but im not sure where should i put that sentence on the code and i have doubts if its gonna be simple as that
Logged
Offline Offline
Newbie
View Profile
i added a servo but with no control of comparators.. i have problem with that part  smiley-sweat .I wanna turn the servo on for 20 secs when humidity is lower than 40%. Anyone?
#define dht_dpin 14
#include <Servo.h>
Servo myservo;
byte bGlobalErr;
byte dht_dat[4];
int pos = 0;
void setup(){
        myservo.attach(9);
        lcd.begin(16, 2);
        InitDHT();
        delay(300);
        delay(700);
void loop(){
        if ( flip & 1 )
        flip++;
        ReadDHT();
        case 0:
        case 1:
        case 2:
        case 3:
        default:
        delay(800);
        for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
void InitDHT(){
void ReadDHT(){
        bGlobalErr=0;
        byte dht_in;
        byte i;
        delay(18);
        if(dht_in) {
                bGlobalErr=1;
                return;
        if(!dht_in) {
                bGlobalErr=2;
                return;
        for (i=0; i<5; i++)
        {bGlobalErr=3; }
        byte i = 0;
        byte result=0;
        return result;
« Last Edit: November 20, 2012, 04:49:27 pm by eclipsear » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
You don't "turn on a servo". Please describe exactly what you mean by that. While you are thinking about it, look at the blink without delay example.
Logged
Offline Offline
Newbie
View Profile
Quote
yeah sorry for the misleading words, i have the sweep servo code but i still need the comparations when temperature is higher than 25 C and the when humidity is lower than 40% turn on a led
this code have the servo sweep, the dht11 + lcd but no parameters for comparation
#define dht_dpin 14
#include <Servo.h>
Servo myservo;
byte bGlobalErr;
byte dht_dat[4];
int pos = 0;
void setup(){
        myservo.attach(9);
        lcd.begin(16, 2);
        InitDHT();
        delay(300);
        delay(700);
void loop(){
        if ( flip & 1 )
        flip++;
        ReadDHT();
        case 0:
        case 1:
        case 2:
        case 3:
        default:
        delay(800);
void InitDHT(){
void ReadDHT(){
        bGlobalErr=0;
        byte dht_in;
        byte i;
        delay(18);
        if(dht_in) {
                bGlobalErr=1;
                return;
        if(!dht_in) {
                bGlobalErr=2;
                return;
        for (i=0; i<5; i++)
        {bGlobalErr=3; }
        byte i = 0;
        byte result=0;
        return result;
Logged
Pages: [1]   Go Up
Print
Jump to:
