Topic: Trying to control servo with push button (Read 1 time) previous topic - next topic
jag3498
First of all, I do not have all that much programming experience. I want to control a servo with a button, so that I press the button and it moves the servo in a certain way, but this code will not work for me. I press the button and the servo will go back and forth 4-5 times.
#include <Servo.h>
Servo door;
int button;
pinMode(4, INPUT);
door.attach(9);
door.write(0);
button = digitalRead(4);
if (button == HIGH) {
delay(10);
     door.write(180);
   door.write(0);
Thanks,
Jack
AWOL
jag3498
Are you saying make the button var a float?
Arrch
No, he is saying that button needs either a pull down resistor, a pull up resistor or the code needs to enable the internal pull-up resistor.
AWOL
No, I'm asking how the switch is connected.
jag3498
The push button is on a breadboard, with a wire from 5v to the first push button pin, then a wire from the other pin to the 4 pin
liuzengqiang
In this case, you are missing a pull-down resistor between arduino pin and ground. Use anything between 2K ohm and 40K ohm.
You will want to reverse the logic of your push button so you can use the internal pull-up resistor, so you don't have hook up a resistor.
jag3498
liuzengqiang
You are welcome. I still recommend using the internal pull-up resistor. It's easy. No additional resistors on your breadboard.
