Author Topic: LPD8806 RGB LED strip support  (Read 1689 times)
I have been running various LED strip projects based on the LPD8806 chipset.
Is anyone trying to port the libraries for the LPD8806 chipsets to the Due ?
I'm looking forward to participating in testing any good trial
Thanks,
Rudy
bump.
I have a similar problem.  I'm getting compile errors when trying to verify the LEDbeltKit example.  I'm doing
this in Arduino 1.5.1r2.  Any ideas on what header file needs updating?
Thanks,
Jon
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp: In member function 'void LPD8806::updatePins(uint8_t, uint8_t)':
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp:62: error: cannot convert 'volatile RwReg*' to 'volatile uint8_t*' in assignment
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp:64: error: cannot convert 'volatile RwReg*' to 'volatile uint8_t*' in assignment
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp: In member function 'void LPD8806::startSPI()':
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp:84: error: 'SPI_CLOCK_DIV8' was not declared in this scope
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp:89: error: 'SPDR' was not declared in this scope
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp: In member function 'void LPD8806::show()':
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp:129: error: 'SPSR' was not declared in this scope
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp:129: error: 'SPIF' was not declared in this scope
C:\Users\Jon\Downloads\arduino\arduino-1.5.1r2\libraries\LPD8806_master\LPD8806.cpp:130: error: 'SPDR' was not declared in this scope
Forum Administrator
Milano, Italy
The library seems to use AVR specific registers to drive SPI.
Someone should made a porting of the library to SAM3X CPU, or convert the lib to use SPI library bundled in Arduino IDE.
Can you post a link to the library code(just to give it a look)?
C.
The library I'm using is the one from Adafruit posted on github on https://github.com/adafruit/LPD8806
KR,
Rudy
Forum Administrator
Milano, Italy
I see,
open LPD8806.cpp and change this (line 89):
  SPDR = 0; // 'Prime' the SPI bus with initial latch (no wait)
with:
  SPI.transfer(0x00);
and replace this (line 128):
    for (i=0; i<n3; i++ ) {
      while(!(SPSR & (1<<SPIF))); // Wait for prior byte out
      SPDR = pixels[i]; // Issue new byte
with this:
      SPI.transfer(pixels[i]);
and tell me how it goes.
C.
Thanks, that helped to clear a bunch of my errors.  I still have a few more.  I'm not sure if the type RwReg and uint8_t are the
same, and also the SPI_CLOCK_DIV8 doesn't seem to be declared, and I'm not sure what value it should be.
Thanks,
Jon
Forum Administrator
Milano, Italy
Yeah,
with SPI_CLOCK_DIV8 you get a 2Mhz SPI clock from an Atmega328 running at 16Mhz, since the Due runs at 84Mhz you need 42 to obtain the same clock. So replace SPI_CLOCK_DIV8 with 42.
About the registers try to change the declaration volatile uint8_t* to volatileuint32_t*.
C.
Hello,
I have the same problème than Rudyv
I follow what you said Cmaglie and numbers of errors has decreased !
But I still have errors smiley-sad :
LPD8806.cpp: In member function 'void LPD8806::updatePins(uint32_t, uint32_t)':
LPD8806.cpp:58: error: cannot convert 'volatile RwReg*' to 'volatile uint8_t*' in assignment
LPD8806.cpp:60: error: cannot convert 'volatile RwReg*' to 'volatile uint8_t*' in assignment
LPD8806.cpp:85: error: 'SPDR' was not declared in this scope
LPD8806.cpp:125: error: 'SPSR' was not declared in this scope
LPD8806.cpp:125: error: 'SPIF' was not declared in this scope
LPD8806.cpp:126: error: 'SPDR' was not declared in this scope
Have you other ideas in order to solve that ?
Thank you for all
Hi, I made some progress and tried today to re-use an LPD8806 library from mbed, as it is ARM based I tried to see if I can get it to work.
Unfortunately it gives me some compiling issues. I'll insert the program and the used 8806.h and 8806.ccp files.
Can someone have a look and let me know how we can get this working ?
The 8806.h file is
// Arduino Due library for LPD8806 led strip, borrowed from MBED.
// Mbed library to control LPD8806-based RGB LED Strips
// (c) 2011 Jelmer Tiete
// This library is ported from the Arduino implementation of Adafruit Industries
// found at: http://github.com/adafruit/LPD8806
// and their strips: http://www.adafruit.com/products/306
// Released under the MIT License: http://mbed.org/license/mit
// standard connected to 1st hardware SPI
// LPD8806  <> MBED
// DATA     -> P5
// CLOCK    -> p7
#if (ARDUINO >= 100)
 #include <Arduino.h>
#else
 #include <WProgram.h>
#endif
#define HARDWARE_SPI 1
#ifndef LPD8806_H
#define LPD8806_H
class LPD8806 {
 public:
  LPD8806(uint16_t n);
  void
    begin(void),
    show(void),
    setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b),
    setPixelColor(uint16_t n, uint32_t c);
  uint16_t
    numPixels(void);
  uint32_t
    Color(uint8_t, uint8_t, uint8_t);
 private:
  uint8_t
    *pixels;     // Holds LED color values
  uint16_t
    numLEDs;     // Number of RGB LEDs in strand
  void
    writezeros(uint16_t n);
#endif
The 8806.ccp file is the following
//Library for Arduino Due LPD8806
//taken from MBEd as it is ARM based
//Mbed library to control LPD8806-based RGB LED Strips
#include "LPD8806.h"
#include <SPI.h>
//here something goes wrong
SPIClass SPI = SPIClass( SPI_MODE0 );
SPI.begin();
//SPI spi(p11, p12, p13); // mosi, miso, sclk
LPD8806::LPD8806(uint16_t n) {
    // Allocate 3 bytes per pixel:
    if (NULL != (pixels = (uint8_t *)malloc(numLEDs * 3))) {
        memset(pixels, 0x80, numLEDs * 3); // Init to RGB 'off' state
        numLEDs     = n;
void LPD8806::begin(void) {
    // Setup the spi for 8 bit data, low steady state clock,
    // first edge capture, with a 2MHz clock rate
    //spi.format(8,0);
    //spi.frequency(2000000);
    SPI.setClockDivider(21);
    // Issue initial latch to 'wake up' strip (latch length varies w/numLEDs)
    writezeros(3 * ((numLEDs + 63) / 64));
uint16_t LPD8806::numPixels(void) {
    return numLEDs;
void LPD8806::writezeros(uint16_t n) {
    while (n--) SPI.transfer(0x00);
// This is how data is pushed to the strip.  Unfortunately, the company
// that makes the chip didnt release the  protocol document or you need
// to sign an NDA or something stupid like that, but we reverse engineered
// this from a strip controller and it seems to work very nicely!
void LPD8806::show(void) {
    uint16_t i, nl3 = numLEDs * 3; // 3 bytes per LED
    for (i=0; i<nl3; i++ ) {
    // Write latch at end of data; latch length varies with number of LEDs
    // We need to have a delay here, a few ms seems to do the job
    // shorter may be OK as well - need to experiment :(
// wait_ms(3);
// Convert R,G,B to combined 32-bit color
uint32_t LPD8806::Color(uint8_t r, uint8_t g, uint8_t b) {
    // Take the lowest 7 bits of each value and append them end to end
    // We have the top bit set high (its a 'parity-like' bit in the protocol
    // and must be set!)
    return 0x808080 | ((uint32_t)g << 16) | ((uint32_t)r << 8) | (uint32_t)b;
// store the rgb component in our array
void LPD8806::setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b) {
    if (n >= numLEDs) return; // '>=' because arrays are 0-indexed
    pixels[n*3  ] = g | 0x80;
    pixels[n*3+1] = r | 0x80;
    pixels[n*3+2] = b | 0x80;
void LPD8806::setPixelColor(uint16_t n, uint32_t c) {
    pixels[n*3  ] = (c >> 16) | 0x80;
    pixels[n*3+1] = (c >>  8) | 0x80;
    pixels[n*3+2] =  c        | 0x80;
The error I get when compiling is the following:
C:\Users\Rudy\Program Files\arduino-1.5\libraries\LPD8806\LPD8806.cpp:19: error: no matching function for call to 'SPIClass::SPIClass(int)'
C:\Users\Rudy\Program Files\arduino-1.5\hardware\arduino\sam\libraries\SPI/SPI.h:29: note: candidates are: SPIClass::SPIClass(Spi*, uint32_t, void (*)())
C:\Users\Rudy\Program Files\arduino-1.5\hardware\arduino\sam\libraries\SPI/SPI.h:27: note:                 SPIClass::SPIClass(const SPIClass&)
C:\Users\Rudy\Program Files\arduino-1.5\libraries\LPD8806\LPD8806.cpp:21: error: expected constructor, destructor, or type conversion before '.' token
Who can help me out ?
KR,
Rudy
Forum Administrator
Milano, Italy
Try to comment out
The SPI object in Arduino is pre-instantiated.
(and remember to #include <SPI.h> in your sketch, I didn't checked)
C.
I have put #include <SPI.h> in my sketch and in the lpd8806.ccp file.
I commented out the code you asked
//SPIClass SPI = SPIClass( SPI_MODE0 );
Then i get the following error when i compile:
What should I try next ?
KR, Rudy
Adafruit has updated their library for the lpd8806 led strip and it works. So my issue is solved.
Thanks for those who helped me in finding a solution.
Kr, Rudy
