Topic: slip ring current rating (Read 578 times) previous topic - next topic
freakdaddy
I would like to purchase this slip ring...
http://www.ebay.com/itm/Capsule-Tiny-Compact-Slip-Ring-24-Circuits-OD-22mm-90-Deg-V-groove-Design-ZSRS-A-/300694455546?pt=LH_DefaultDomain_2&hash=item4602c944fa
It claims 2A per circuit with #30 wire.  Everything I see lists about .86A for #30 wire.  What would be the correct current given that it has #30 wire?
Osgeld
seems to be pretty thick for 30 gauge, its probably a Chinese 24 gauge (ie 24 gauge worth of insulation and 30 gauge of metal)
.86A is the safer bet, I really wouldnt push it much further as the longer the wire, theres more resistance, and stuff gets hotter
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
MarkT
If you dont need all 24 connections you can parallel some of them up for more current handling - and less chance of noise.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
