Loading...
Pages: 1 [2]   Go Down
Author Topic: controlling servos through serial  (Read 462 times)
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Suppose you type "000000101" in the serial monitor, and hit send. How many passes through loop() do you think it takes all that data to arrive?
Way more than you are coding for, that is certain.
Quote
it should be
myservo3.attach(smiley-cool;
Really?
Logged
Offline Offline
Newbie
View Profile
...... i keep holding the shift key..... it should be myservo3.attach(smiley-cool......... there!!! i feel very proud of myself now
but what was that about it being way more then im coding for?
if i keep out the increment movement and the pressure sensor code, and just have "myservo3.write(n3);" then it works just fine. as sson as i try to add grip control it falls apart.
how do "code" for more? im pretty new to arduino
Logged
Offline Offline
Newbie
View Profile
.... could you over look the smiley face please. i dont know how to stop it happening, its not the shift key anyway
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
You need to send a packet. That has a (optional) start pf packet marker, and a (required) end of packet marker.
You read serial data, whenever it is available. You append the data to an array if the char/byte read is NOT the end of packet marker. If it is, you use the data in the array.
You do not assume that all the data arrives in one iteration of loop, and you do not use the data in the array until the whole packet arrives.
Here's an example:
Code:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Quote
Use the # in the post tool bar for a code box. You have been using the quote box tool (put cursor over the tool icon to see what it does). Below is some test code for multiple servos that uses a , as an end of string delimiter. Note that I don't have servos currently to test the code.
Code:
//zoomkat 11-22-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: 1 [2]   Go Up
Print
Jump to:
