Author Topic: Very quick question about byte and int.  (Read 242 times)
Maryland, USA
I noticed that a lot of example sketches that I download from here or elsewhere use int type constants and variables instead of byte even when byte would be enough:
const int LED = 13 ;  // 13 is < 256, byte would be enough
With an 8 bit MCU I would think using byte would be better (faster and half the memory) than int.
My question is: is there a drawback in using byte rather than int or, putting it in another way, an advantage using int instead of byte when byte is enough?
TIA
There are three kind of people in the world: Those who can count, and those who can't
Austin, TX
CMiYC
better is subjective
I suspect "int" is used because new programmers more easily associate numbers with integers.
www.cmiyc.com - A guide to being an Enginerd
Seattle, WA USA
Seattle, WA USA
Using byte is generally better. Typing byte, instead of int, requires 33% more effort.
And using #define led 13 uses zero bytes (but lots more effort!)  smiley
Valencia, Spain
Code can be much smaller/faster with bytes.
No, I don't answer questions sent in private messages...
Austin, TX
CMiYC
And using #define led 13 uses zero bytes.
In this case, so does the const keyword.
Edit: Found it.  There's a thread floating around where a forum member did some experiments and showed that const also consumes no RAM.
http://arduino.cc/forum/index.php/topic,86800.0.html
In particular, Nick's example:
http://arduino.cc/forum/index.php/topic,86800.msg651320.html#msg651320
« Last Edit: November 22, 2012, 12:20:11 pm by James C4S » Logged
const byte, const int, and #define should all use zero bytes unless you don't use any optimizations or take the address of the constant.
int is a standard C++ type and byte isn't, so int is more `portable' and recognizable to people not used to arduino. uint8_t is more standard but more annoying to type, and in C and C++ you have to include a header file to use it (stdint.h). char is undefined as to whether it's signed or unsigned so if you care you have to put `unsigned' in front of it which is a whole lot more effort.
There's no real good solution. I generally stick with uint8_t in libraries, but I think byte is best for sketches
