Author Topic: USB Host MouseController problem  (Read 476 times)
Czech
Hi all please help me
I´m testing USB Host MouseController example - working great ! But when adding some code like ADC read or pin control, that working only when moves mouse !!!!!
This is normal or error in USB Host library ?
Thanks help Kamil
P.S. sorry my bad english
Venezuela
Ground.......ground........always ground
I tried it adding the Blink code and both worked OK. Here the code I tried.
 Mouse Controller Example
 Shows the output of a USB Mouse connected to
 the Native USB port on an Arduino Due Board.
 created 8 Oct 2012
 by Cristian Maglie
 http://arduino.cc/en/Tutorial/MouseController
 This sample code is part of the public domain.
// Require mouse control library
#include <MouseController.h>
// Initialize USB Controller
USBHost usb;
int led = 13;
// Attach mouse controller to USB
MouseController mouse(usb);
// variables for mouse button states
boolean leftButton = false;
boolean middleButton = false;
boolean rightButton = false;
boolean left;
boolean middle;
boolean right;
// This function intercepts mouse movements
void mouseMoved() {
  Serial.print("Move: ");
  Serial.print(mouse.getXChange());
  Serial.print(", ");
  Serial.println(mouse.getYChange());
// This function intercepts mouse movements while a button is pressed
void mouseDragged() {
  Serial.print("DRAG: ");
  Serial.print(", ");
// This function intercepts mouse button press
void mousePressed() {
  Serial.print("Pressed: ");
  if (mouse.getButton(LEFT_BUTTON)){
    Serial.print("L");
    leftButton = true;
  if (mouse.getButton(MIDDLE_BUTTON)){
    Serial.print("M");
    middleButton = true;
  if (mouse.getButton(RIGHT_BUTTON)){
    Serial.print("R");
    Serial.println();
    rightButton = true;
// This function intercepts mouse button release
void mouseReleased() {
  Serial.print("Released: ");
  if (!mouse.getButton(LEFT_BUTTON) && leftButton==true) {
    Serial.print("L");
    leftButton = false;
  if (!mouse.getButton(MIDDLE_BUTTON) && middleButton==true) {
    Serial.print("M");
  if (!mouse.getButton(RIGHT_BUTTON) && rightButton==true) {
    Serial.print("R");
  Serial.println();
   pinMode(led, OUTPUT);
  Serial.println("Program started");
  delay(200);
  // Process USB tasks
  usb.Task();
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
It could help also if you show us the code you ran that has the problem.
Czech
I´m testing your code but not working - same problem. Few first blink working - after few second stoped blinking. When mouse move again few second working.
Arduino IDE v1.5.1r2
WinXP SP3 and
Genius USB mouse Net Scroll 120
powering over USB programming port
Kamil
Venezuela
I have my PC connected to the programming port (same drive) and my mouse to the Native port (Bossac driver).
I noticed that the LOW led status is taking a bit longer (around 2 sec) but still blinking.
